Washing Machines Logo
O
Ollie Posted on Dec 10, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
F05 wots that mean - Washing Machines
Dave Yale
Level 2:
Habit-Forming:
New Friend:
  • Expert 60 Answers
  • Posted on Dec 25, 2018
Dave Yale
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
60
Questions
0
Helped
47724
Points
160
Is this on Hotpoint or Indesit ashing machine? If so then error code F05 washing machines means the pressure switch has "jammed" on.
F05 fault after replacing brushes
F05 - NTC failure (SC/OC)
All appliances managed by the electronics measure the temperature using a thermistors. These thermistors changes resistance depending on the temperature. There are two kinds of thermistors, NTC and PTC.
NTC has a negative temperature coefficient which means that with increasing temperature the resistance decreasing (used in washing machine, dishwasher, dryer, refrigerator....etc).
PTC has a positive temperature coefficient which means that with increasing temperature the resistance increasing (used in oven, refrigerator for starting compressor...etc).
If you look in the table below, it is clear that the resistance value of 100 ohm means that is NTC faulty. So, I really do not understand how it is possible that the resistance increases with temperature?
Resistance of NTC depending on temperature
0 °C 35.9 kohm
30 °C 9.8 kohm
40 °C 6.6 kohm
50 °C 4.6 kohm
60 °C 3.2 kohm
70 °C 2.3 kohm
95 °C 1.1 kohm
Dado
1helpful
Error F05 on my awod as147 steam washing maching
F05 for Whirlpool washers decodes as 'NTC failure'. NTC stands for Negative Temperature Co-efficient and all that means is the water temperature sensor ;-0)
I have heard that occasionally it can be brought back to life by pouring in a few kettles of hot water into the washer, leaving for 10 minutes, spinning the water out and re-trying. If it doesn't work it means a service call. Sorry ;-0(
Good luck,
John C.
1helpful
Comes up in the display f05
F05 means pressure switch jammed on full.
Remove the lower rear panel of washer.
Locate and remove the large black hose fastened to bottom of drum.
Remove and clean plastic fillter inside hose.
Reassemble and test.
My washer is say f-o5 wot dose that mean
an f05 error message means that the pressure switch is jammed on empty or as already said a problem with pump.
http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&t=4791&start=0&postdays=0&postorder=asc&highlight=
See above.
20helpful
F05
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit and test.
Please rate my solution.
Thankyou.
3helpful
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Remove lower rear cover of washer.
Locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
19helpful
4answers
3helpful
2answers
Wt960p hotpoint
The error F05 indicates that the pressure switch is jammed on full.
The only thing you can do your self is to check the filter is not blocked.
Remove lower rear panel of washer, locate and remove large black hose fatened to bottom of tub, watch out for water running out.
Remove and clean plastic filter inside hose.
Refit filter and hose, test for leaks.
If problem still persists, then could be faulty pressure switch or blockage in the pressure system.
Let me know if you require any firther info.
Pleas rate my solution.
Thanks.
Fo5
f05 means a blockage usually. check the drain hose is clear and there may be something in your filter or pump.
Top Washing Machines Experts
john h
