Yes it is possible that element is bad, before I started throwing parts at it would check hi limit disc. Also if you have 3 wire a 240 will read 240 between the hot wire and from neutral or ground 120. 120 will measure 120 between neutral.
SOURCE: heating element continuity?
Unplug the dryer from the wall. There are 2 wires connecting power at the heating element. Take one of these wires off, doesn't matter which one, but take at least one of the 2 off. Then put your meter probes across the terminal of the heating element where you took the 1 wire off and the other terminal of the heating element that still has a wire on it. Your meter will pretty much read full continuity if good, no reading at all if bad. Also check from one of these terminals of the element with one meter probe going to the metal frame of the unit. You should get no reading. If you do the element is shorted and would have likely tripped your house breaker.
Better to test a heating element for voltage with your meter like I described to you in your other question. I've seen heating elements read good when just doing a continuity test, however once voltage is applied and they start to heat they can expand and open up, thus not work, even though testing good when doing just a continuity test. Not always, but sometimes, it does happen enough to note to you.
SOURCE: Kenmore Dryer runs with no heat
An open circuit does mean the element is bad and will need to be replaced.
Just in case though, make sure your meter is working properly by touching the leads together. You should get a reading.
SOURCE: Whirlpool duet electric wil not heat
Remove 1 wire from the element . Your 220 V comes from ...110 motor , 110 control board . Check which wire is not getting 110 V , trace it and see which it comes from . That will tell you which one is defective .
SOURCE: Maytag performa dryer PYE2300AZW
my dryer was working perfectly fine, but I think i had way too much laundry this day. anyhow, it just stopped working. the weird thing is the timer still runs I turn it to 90 and then it stops at 0. WEIRD!! i had my dad and husband take it apart, but of course we are reading the blueprints and tring to find matching numbers but no can do. we give up. HELP
sign the Dryer Monster
SOURCE: My Kenmore 400series 6942 electric
This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. if there is no heat then one of the thermal fuses is bad you will need to check the continuity on them and replace the one that does not have any continuity
