Televison & Video Logo
T
Tim Schreiber Posted on Dec 07, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Repair sony kd-60x690e tv power supply main controller board
Franco Dosil
Level 3:
Top Expert:
  • Sony Master 10,542 Answers
  • Posted on Oct 03, 2019
Franco Dosil
Sony Master
Level 3:
Top Expert:
Answers
10542
Questions
0
Helped
377715
Points
178965
Nate Archibals
Level 3:
  • Master 1,149 Answers
  • Posted on Dec 07, 2018
Nate Archibals
Master
Level 3:
Answers
1149
Questions
0
Helped
129600
Points
2514
A very simple solution to r epairing all by yourself is getting help from handbooks, they're very detailed and complete in every way so for me it was my best source to repair
one of the top sites for this is https://big-manuals.com/
5 Related Answers
Jack South
  • 195 Answers
  • Posted on Oct 10, 2009
SOURCE: olevia 437-s11
Most likely the CCFL inverter has been the problem all along....
Anonymous
  • Posted on Dec 06, 2009
SOURCE: PDP5016H Akai Plasma TV
is the control board the one with the rca jacks on it,for sound and video input?if so email me at [email protected],i need one.
Chi Chu
  • 8457 Answers
  • Posted on Jun 22, 2010
SOURCE: plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like Shopjimmy.com,Ebay.com to buy the refurbish power supply board for the replacement.
bshldn
Loretta Northcutt
  • 736 Answers
  • Posted on Feb 05, 2011
SOURCE: I have Samsung UN46B8000XFXZA LED TV. After power
Yes based on your testing it appears that the power supply is at fault solely and you can opt to attempt a repair or replace it altogether. Unfortunately you will not be certain that the main board does not also need to be replaced until you have repaired the power supply.
Anonymous
  • Posted on Feb 07, 2011
SOURCE: My VP504fhdtv10a vizio plasma TV when connect
Logic Control D Board got nothing to do with this problem. This is your main power supply gone bad(usually not the sub power supply). I just repaired my VIZIO by replacing main power supply. Just remove back cover and your board will be right in the middle of the screen. Just get board part/serial # and google it. My best price was through eBay(around $100). Everything is fine now.
Sony Model KD-60X690E no picture
Its probly old and worn out. Be cheapr to buy new cause soon u be replacin more parts
2answers
Sony KD60X690E Won't Stay Powered On
Not sure your skill level at repairing electronics, but I will include some basics if you are able to do some soldering.
I have worked on many TV's and the issue you are describing is typically one of two things.
FIRST take the back off your TV have a look at the power supply look for the capacitors (I have attached a photo and the items circled in red are the main capacitors to focus on) look to see if any of them appear to be bulging. A normal capacitor has an "x" marked on the metal top - this "x" should be flat or even a bit caved in. If it is round and popping up then that capacitor should be replaced. You can check the printed uf on the side and voltage (such as 1000 uf / 50v). Then look them up/order them from a place like mouse com or digikey com.
Secondly the other common issue I find is a "cold" or broken solder joint.
Take the power supply out of the TV look at the back of the board with a magnifying lens or watch repair glasses. Look very closely over the solder joints for cracks or breaks. In particular focus on the solder connections of the 3 pins transistors attached to the heatsinks. (In the image I attached they are the yellow circled items but look on the back of the power supply to where these pins attach on the green bottom side).5f7dee65-902e-408a-bf21-d6f9260d03f3.jpg
(For some reason it seems like the attached image is showing as very low quality - here is an external like if it will allow me to link one: https://i.ibb.co/2vcRq9v/Sony-KD-60-X690-E-PSU.jpg )
Sony tv squeal
Usually out of tolerance capacitors, resistors going high, and leaky diodes in the switchmode power supply can cause a high pitched squeal from any TV. Occasionally a bad transformer winding on the same board can also cause the noise but can also be a deflection fault. Check the PSU board for any bulging or dodgy looking electrolytics first then proceed from there. If you have a multimeter, you can measure the diodes and resistors. Before going any further, and worrying about repair costs, do some simple checks first. You may end up needing a replacement PSU PCB for the model of TV you have; a refurbished board is cheaper than a new one and if you fit it yourself, you save on labour costs. Start with the power supply board and work from there.
1helpful
Hi I have a sony tv that wont turn on
It is a power supply regulator board problem. To get more details about it, and how to repair the poser supply fault, visit this site named "Electro-help"; to the search box of either google or yahoo. It have description about how to repair the poser supply regulator section. visit it, and pull up older posts there.
Never forget to type in 'hyphen' in between words.
14helpful
We have a SONY kd-34XBR960 I turned it off and
Turning your tv off did not cause this issue, so don't blame yourself for that. A 6 or 7 blink shutdown is because one of the two switch mode power supply control ic's have failed. the part number on them is mcz3001. They are located on the "D" baord, i don't recommend replacing this yourself because even with a tv unplugged from the wall high voltages still exist in the set.
A repairman may preform one of the two following things, he may change the whole D board or he may replace the individual components. The repair will cost around $200 if they replace the components, and if they replace the board it will cost more.
My sony kdf-42we655 has 7 flashing red blinks. please help.
Audio Protect (7 Flash): When DC voltage is detected at the speaker or
woofer outputs, IC3604/pin128 (TV-micro) goes low and IC3604 turns off
the main power (AC relay turns OFF).
Troubleshooting Tips:
1) Main cause of defective will be located on the KD-board
2) Confi rm KD-board is securely seated on the G2-board
3) Replace KD-board
Picture quality poor
1. Try this - hold the menu button down for 10 seconds. TV should power up; you will have to turn off front panel buttons on menu.
2. You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
if not please follow these:
3) Replace KD-board
Thats a fairly complex Chassis. Unless youre really good at dissassemble and reassembly of small components, I would suggest a Sony authorized reapir tech do the repair.
Certainly, I can help you. I would recommend going to the following link and getting the service manual so he can see first hand disassembly instructions and testing proceedures. Its only 10.99 and they email it to you shortly after purchase. The manual is a valuable resource as it will have part numbers in case you do need a new KD board. heres the link.
http://servicemanuals.vstore.ca/
DON'T FORGET TO RATE:
1helpful
Power/standby light flashes 7 times and the tv doesn't turn on
3) Replace KD-board
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
