SOURCE: Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
http://ati.amd.com/support/driver.html
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
SOURCE: toshiba satellite pro m15 s405 video card replacement
The video card is replaceable and is relatively simple for those comfortable with laptop disassembly.
SOURCE: Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
SOURCE: new wide screen monitor incompatibility issues with older comp
The two cards(Gforce Nvidia card) might not be compatible for your motherboard because they're for heavy graphics like playing games, and *********** board is old that you;ve mentioned. including the message memory range unavailable. Try using your old card with the new monitor.
SOURCE: 2 pin power conection for my Radeon HD 2400 pro video card
To smithbrother, it says AGP, there is no such thing as crossfire for AGP.
The card uses a jumper line, its a 2 pin, its for the fan,
tiny little jumper.
I think you should connect the company, I don't think anyone has the little 2 pin connector/jumper for the fan.
