SOURCE: Printer will not read SD card from Panasonic Lumix DMC TZ3
Put the card in an adapter or in your computer. Make sure the pictures are not in folders. The printer is unable to read them if they are.
Also, the file size of the picture cannot be over 8 MB and the image size has to be below 12 megapixels.
SOURCE: Option to use SD card as usb not available
Ignore the manual..It directs you to drill down into the settings for the sd card and set it as mass storage..no such option exists in the menu.
Follow this:
plug in usb
go to NOTIFICATIONS
touch the notification in the list that refers to the usb having been connected..you will receive a prompt to "mount" the sd card.
now you can access it.
viola.
bada bing
SOURCE: My computer does not recognize my SD 2GB SD Flash
yes you can directly use the SD card slot, make sure you unlock the write protection before inserting it into the slot if you wish to modify or copy the contents from or to the card.
