SOURCE: canon printer
Canon printer pixma ip6220D is showing error code 5100 and alarm light flashing. Help me how to repair it?
SOURCE: Canon S630 Printer. Yellow light blinks 7 times, green once.
7 Blinks says that your printhead has gone out. Just needs a new printhead, QY6-0034-000. around $40.00
SOURCE: getting error code 6A00-Canon PIXMA MX850 all-in-one printer
The error indicates that the slide the cartridges run on has debris buildup or a component of the printer is blocking the cartridges ability to slide.
Steps to fix...
1. Unplug printer from power source
2. Slide the cartridges to the middle and inspect the slide for a buildup of "gunk" or pieces of debris. Remove what you see and clean the slide with a lint free rag and isopropyl alcohol
3. Look for any part of the printer that may have become dislodged or moved from vibaration and use and try to put it back in to place.
4. Get some "canned air" at any computer or office supply store and blow the printer out thoroughly.
Plug the printer back in and it should work again.
SOURCE: Canon Pixma MX300 - error code 5B00 - check
Try it works for most Canon
Hi you can try
Solution:
All The Best: Pineworks
SOURCE: Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the
"stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel
button, press and hold the Power button.
(DO NOT release the buttons.
The Power LED lights in green to indicate that a function is
selectable.)
2) While holding the Power button, release the
Resume/Cancel button. (DO NOT release the Power button.)
3) While
holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and
Resume/Cancel buttons. (Each time the
Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately,
Alarm in orange and Power in green, starting with Alarm LED.)
4)
When the Power LED lights in green, press the Resume/Cancel button the
specified number of time(s)according to the function listed in the table
below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power
LEDs light alternately, Alarm in orange and Power in green, starting
with Alarm LED.)
4 times----Green (Power)------Waste ink counter
resetting
