Ovens Logo
Mike Huntoon Posted on Dec 06, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
GE JT5000 built in 30" oven. Self-installed. Light won't turn off. Get "shut door" msg when trying to turn on. Bad wiring job or defective oven? GE asked me to move latch and it wouldn't budge.
Stephen Matthews
Level 2:
Habit-Forming:
  • Expert 107 Answers
  • Posted on Jan 24, 2019
Stephen Matthews
Expert
Level 2:
Habit-Forming:
Answers
107
Questions
0
Helped
31362
Points
215
If you installed the oven without the door on, open the door completely, then turn the power off at the breaker, then go upstairs and shut the door and then go back downstairs and turn the power back on. if that doesn't work call for service.
5 Related Answers
Anonymous
  • Posted on Dec 20, 2007
SOURCE: GE P7 Oven
I, too, have lost my manual and none of the timers work. I can never remember how long to run the clean cycle for, but will turn it off as it has been a little over 2hours and your post mentions 1.5hours.
I initiate the cleaning cycle by completing steps mentioned above and then turning the top dial (which has a clean range on it) clockwise until the clean light comes on. I then just time it by my watch to turn it all off. Then I wait a couple of hours before attempting to open the door. Don't forget to take the racks out, they are not suppose to go through the Clean cycle.
Good Luck,
Linda
Anonymous
  • 770 Answers
  • Posted on Jan 26, 2008
SOURCE: Thermador built-in double ovens p/n SCD 302 TP
post your email i will send u the manual
Anonymous
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Anonymous
  • Posted on Jun 18, 2009
SOURCE: Ge Profile built-in 27 inch wall oven -- When I
f9 means your control panel needs to be replaced..chances are part is not covered and if it is the only way you can obtain it is through having service
TheMobilian
Dan Webster
  • 8221 Answers
  • Posted on Apr 11, 2010
SOURCE: self cleaning oven error code FSEO
Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "was surprised at such a quick response...needed additional information to provide a better solution...very grateful for the assistance"
Frigidaire electric wall oven wont open error code f90
Error Code E90 typically means that you have a faulty motor door latch, lock motor assembly, door light switch or a defective EOC. You would need this to be diagnosed by a professional technician in order to properly repair the wall oven.
My self cleaning oven door lock will not come unlocked. is there a way to do it manually.
Try removing the power from the appliance for at least 30 minutes (unplug it or turn off the breaker).
Turn it back on after the wait time has passed and see if the door will release. If not, you may have a bad oven door interlock switch or bad board.
Feb 24, 2011 • GE Ovens
Oven shuts off 10 minutes into self clean cycle or while broiling
check for loose connection on the door sensor or micro switch you ay need to change the micro swich if faulty
3answers
Can't get the GE P7 door lock engaged in order to
have to have a repairman come out and reset the code on the inbord computer not a simple fix i know i sell appliances
1helpful
2answers
I replaced the WBX20154 glowbar for my oven as
The model number on a built in oven is usually found on the oven frame, just behind the oven door. (should be a metal tag, or silver sticker) It is NOT LIKELY that the oven valve is bad. (although if you have a self clean model, they would have seperate valves for bake and broil)
When the oven is turned on, there should be 120 volts across the ignitor. You can test the igniter by putting one wire into the left side and one into the right side of a standard recepticle, but you have to be careful with bare wires and the ignitor gets hot very quickly, and stays hot for awhile, so if you try it, be very careful. I'm assuming that your original ignitor was a round one also (not a flat one). It is very important to use the same type as the original.
I suspect you have a poor electical connection. Make sure wires are stripped back about 1/2 inch, then make sure the ceramic wire nuts are tight when installed.
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
5helpful
Interior oven light won't shut off.
Hi, i would check the pressure switch and its connection as well. either the switch is malfunctioning or the wires and connectors are corroded. simply replacing the wires or switch will fix this issue. the switch is usually located on the rim of the inside of the oven door. it will make contact with the oven door and as the oven door closes, the pressure switch is depressed inwards, thus, opening the circuit and cutting power to the light.
Please rate and god bless:)
1helpful
GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Top GE Ovens Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a GE Oven Expert? Answer questions, earn points and help others
