SOURCE: I have a canon copier
this error is power related. reset the fixing error by pressing * 2 & 8 then * Go to function, clear, error switch off the machine then switch on
SOURCE: canon ir 3035 xerox machine
that is about toner,
- may be toner was empty (the first you must try) after you fill the toner, you must turn off and on again.
- toner sensor was loose or broken (second trial )
- toner motor was not work.(the last)
good luck
SOURCE: My canon machine is IR 3035 and having a error
this is error code for abnormal temperature rise in fixing section.
You can try to reset error in service mode, but if the problem persist you need to change the fixing film unit.
To reset the error:
1) Press the asterisk key " * " on the control panel.
2) Press the 2 and 8 keys of the keypad at the same time.
3) Press the asterisk key " * " on the control panel.
Choose: COPIER>FUNCTION>CLEAR>ERR.
Turn off and back on.
Hope that helps!
