SOURCE: keyless remote is not working & alarm goes off & won's turn off
before doing anything... use the key to unlock the door...then the alarm will not go off
SOURCE: Temperature Alarm
Can you look behind the food and shelves at the back wall near the bottom, if there is a frost build up on the back wall we have an issue with the defrost system, this would cause poor air flow and loss of cooling. I do not have your model number but I am assuming since it is a frost free unit it has an internal fan. If so is the fan running inside, can you feel air out the vent in the top? If not your fan motor may have gone out. The next thing to check is feel the side walls of the freezer, they should be warm. If they are not the compressor may not be running. Let me know the results of these questions and we can go from there.
Testimonial: "Still trying to work out the problems by elimination of various issues. Very good feedback."
SOURCE: Cannot turn off security Alarm
If this is a factory alarm try using the the key in the door lock and turning the door lock manually. I have seen this issue in chrysler models as well. If this does not work try replacing the batteries in the key fob as this will cause falfunctions as well.
SOURCE: powerware ups mod #PW9120100i
You have to turn socket of ups power cord 180 degrees, because the ups is measuring voltage between ground and ac-line.
SOURCE: F1 and F2
Here are the codes for Tappan ranges:
TAPPAN
Range/Stove/Oven Fault Codes
Failure
Code
Condition
Check/Repair
F0 & F1
EOC (Electronic Oven Control) failure
Replace Electronic Oven Control
F2
Oven too hot
Check Bake function, if OK, replace oven temperature sensor
F3
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
F4
Oven temperature sensor shorted
Replace oven temperature sensor
F5, 6, 7
F8
Lock switches
Check switches and replace if necessary
