Kitchen Ranges Logo
Wendy Kremers Posted on Dec 01, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
What does the error code man F9E0. Whirlpool electric range less than one year old.
Chris Huff
Level 3:
Top Expert:
  • Whirlpool Master 6,289 Answers
  • Posted on Dec 01, 2018
Chris Huff
Whirlpool Master
Level 3:
Top Expert:
Answers
6289
Questions
Helped
2014560
Points
74913
F9 or F9 E0
The electrical outlet in the home or the electrical connection to the appliance may be miswired.
If your appliance was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
Unexpected power supply line "noise" during a power outage that the control detected as incorrect voltage may cause the code to display.
If any keys were pressed before a 10 second delay during power up could cause the code to display.
Resolution: Reset Power.
My less than 1 year old whirlpool electric range has an error code of F9E0. What does this mean and how do I fix it.
F9 or F9 E0
Whirlpool stove shooting code F9E0
F9 or F9 E0
Possible Solutions
Reset power to the product:
This code will most often indicate that the appliance is wired incorrectly at the home electrical supply, or at the hard wire connection.
  • If your oven was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
During a power outage, if there was an unexpected amount of power supply line "noise" that the control detected as an incorrect voltage amount, the control could display the F9, F9 E0 or PF Error Code. Also, if any keys were pressed before the 10 second delay interval on power up, this could cause the F9, F9 E0 or PF to appear.
  • Power unit down by turning off the circuit breaker(s) for one (1) minute.
  • Power unit up by turning on the circuit breaker(s).
  • Monitor the oven for one (1) minute to ensure the error code does not display again.
  • Verify oven operation.
Still need help? Call or schedule service.
You may need assistance from a qualified technician. Call 1-866-698-2538 or click below to schedule an appointment.
Schedule Service Online
How do I restart my stove after a F9E0 code flashes?
The control thinks thinks the heating circuit is open was the oven in use when power went out possible one of the leads may have come off or burned off one of the elements I have seen outages damage a lot of controls with oven off try cancel/off, cancel/off then start to go into diagnostic press the 3 or ^ key till you get to errors follow the prompt to reset this my help
Will not get hot
Thank you for submitting your question. The error code is indicating a outlet mis-wiring issue or control board issue. If the unit has been working fine then it will be the control board.
Here is the part to order.
Whirlpool W10476673 Cntrl Elec AppliancePartsPros com
1helpful
I am getting E0 -F2- error on my Whirlpool Gold Accubake oven display. If I press cancel it sometimes will start but has been working less and less. The range is quite old and I do not have a manual. What...
Shorted keypad (also called touch pad)
1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Whirlpool electric range model #RF378PXGQ. Ten
the owner manuel may have a the fault code chart but if you tell me the fault code i might beable to help
Jan 27, 2010 • Ovens
Lower element in oven stopped working. Can I replace this on my own? Oven is less than a year old.
This is generally a simple procedure. May I suggest www.repairclinic.com.
They are an excellent resource for parts and basic instruction.
Top Whirlpool Kitchen Ranges Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
