F9 or F9 E0
The electrical outlet in the home or the electrical connection to the appliance may be miswired.
If your appliance was installed recently (within approximately 3 months), contact a qualified electrician to verify the electrical supply.
Unexpected power supply line "noise" during a power outage that the control detected as incorrect voltage may cause the code to display.
If any keys were pressed before a 10 second delay during power up could cause the code to display.
Resolution: Reset Power
SOURCE: whirlpool electric range RF361 bxdn 0. error codes? PF?
hi Jon
look on the back of the unit, there should be an envelope that has a paper in it, that paper should tell you what the code means.
SOURCE: Samsung 306BHW-Error code 7E
I don't know what the problem is bUT I HAVE THE SAME PROBLEM TOO ON a machine 8 months old
SOURCE: GR448LXPS electric whirlpool range got the error code E1 F1
This Is what the E1-F1 means and what you need to do to fix.
Safety flip flop
Replace Electronic Range Control/Clock (ERC)
SOURCE: What does F-1 mean on the electronic display of stove?
F1 is a failed thermistor control in the control board. Board must be replaced to fix. Part is in vicinity of $120.00
SOURCE: LG LRE30755 Electric kitchen range F-1 fault code
Hello- Control has failed. Replacement boards are available. Need complete model # to chk on part. Not too difficult to replace. Let me know if this info helps and if you need more- Thanks- ED
