Washing Machines Logo
Hi my zanussi jetsystem progress 1400 refuses to spin at all please help
5 Related Answers
A
Anonymous
  • Posted on Oct 09, 2008
SOURCE: zanussi jetsystem 1400 door seal
IF YOU REMOVE THE SEAL UNLESS YOU ARE AN ENGINEER YOU WILL FIND IT EXTREMELY DIFFICULT TO REFIT IT, TO CLEAN OUT THE SLUDGE USE A PLASTIC SCOURING PAD LIKE THE ONES USED FOR CLEANING DISHES. IFTHE SEAL IS BLACK THIS CANNOT BE CLEANED IT IS A CHEMICAL REACTION TO DETERGENTS ETC BUT IS NOT HARMFUL TO ITEMS BEING WASHED HOPE THIS WILL HELP.
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Feb 06, 2009
SOURCE: zanussi jetsystem 1400 not drainng properly.........
There should be a filter located at bottom front right of washer behind a metal cover.
Press on cover to open, and remove filter by unscrewing anti -clockwise.
Also check outlet pipe is not blocked, more so if it goes into a sink waste connection, if it still leaves water in drum, then there is probably a partial blockage else where, which will require further investigation.
Please leave a fixya rating if my solution solves your problem.
Thankyou.
Anonymous
  • Posted on May 19, 2009
SOURCE: How to clean a Zanussi Jetsystem 1400
on my mums zanussi,, after opening door, machine had not drained and spined, closed door again could not get machine to go,, this time could not get door opened..there is power to machine.
Anonymous
  • 155 Answers
  • Posted on Sep 02, 2009
SOURCE: e10 flashing up on my zanussi jetsystem progress
The reason to this problem is due to the electric valve.
The old unit might have gone bad,replace it with a new
one.
beltronic205
Gerry Harvey
  • 1482 Answers
  • Posted on Feb 09, 2010
SOURCE: hi my zanussi jetsystem 1400 8kg the water is not
If its also not spinning or pumping out ..Sounds like the door interlock switch....
Washing machine error
HOLD START AND SKIP TOGETHER AND TELL ME WHAT IT SAYS. Also give model and serial number.
1helpful
6helpful
Zanussi jetsystem 1000 will not do anything
zanussi jetsystem 1000 has stopped spinning the wash ! its missing out the spinning program help ?
3helpful
E10 flashing up on my zanussi jetsystem progress 1400
one.
5helpful
I have a Zanussi Electrolux Jetsystem Progress ZSF 6161 Dishwasher which, no matter what programme I use, stops after 2 seconds and a -10 flashes.
I have a Zanussi Jetsystem Progress ZSF 6161 Dishwasher stops after a few seconds and flashes -30 Any ideas? thanks!
3helpful
5helpful
2answers
Zanussi jetsystem 1400 not drainng properly.........
Thankyou.
Zanussi jetsystem 1400 door seal
2helpful
4answers
Zanussi jetsystem Turbodry 1200
It appears that you may have a faulty door interlock or a faulty PCB. pcb is not really a DIY job as some boards require proramming on certain versions. Regards Advisor
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
