SOURCE: Bluetooth keyboard will not pair to FSC Celsius Mobile H
https://bugzilla.redhat.com/show_bug.cgi?id=114489
There is a patch for that problem.
SOURCE: pairing my Z9i v1.1 headset with my new iPhone
I had a problem with this also, try this.
Turn off both devices then turn on your phone.
make sure your bluetooth option is "ON" on your phone
turn on the blueant z9i
press and hold both volume buttons, while doing that, press the ANT button.
Your blueant should be flashing fast right now and your iphone should be able to find it.
complete the pairing by selecting the blueant headset on your iphone and enter the code "0000"
enjoy
SOURCE: I purchased a new Iphone and my Jabra will not
To remove the list, press and hold the Answer/End button, Volume up button and FM button at the same time. A beep indicates the list was removed from the speakerphone memory. The next time
you power on, the speakerphone will go into pairing mode as the first time you powered your new Jabra CRUISER on.
Thank You
SOURCE: Just purchased Jabra Cruiser 2.
Try to reset and pair it.To reset follow below instruction
Thank You
SOURCE: Connection / Pairing
1. Turn key in position 1 or 2.
2.Press the big buton (with text ' bluetooth' ) for 3 sec; the led will flash rapidley
3. let your iphone search
4. when found enter pincode 62872
5. led will light continuesly, iphone say's he's paired.
