Winter Sports Logo
Donald Williams Posted on Nov 29, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i access the drain plug on my chaincase on a 2011 550 iq xlt polaris snowmobile ? I have the muffler box off, and still can't see it. Do I go through the plate beneath the belly pan?
Marvin
Level 3:
Top Expert:
  • Master 85,242 Answers
  • Posted on Nov 29, 2018
Marvin
Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29036411
Points
266281
Drain plug for what?
5 Related Answers
Anonymous
  • Posted on Mar 18, 2009
SOURCE: 93 polaris xlt tripple wont run to full potential
The issue I had with my 94 was due to an oil adjustment, wich you can find below the carbs. It ran great at full throttle but once it sat at idle, the plugs would get wet and the same type of bog would accure. Get new plungs and make sure all three are firing first, if they are then the oil adjustment is off. If not sorry to say but you may have a bad coil.
Anonymous
  • 35 Answers
  • Posted on Feb 17, 2010
SOURCE: 1997 Polaris XLT Triple. Do I really need to pull
I have 1995 and a 1997 XLT. i have rebuilt the recoil on the 95 and all it takes is the few bolts to take off the cover and take the pipe off. if the 97 is any thing like my dads 94, you may have to pull the engine up a bit, the bottom left bolt cant fully be backed out with out hitting the side of the belly pan retainer, all it takes to pull the motor up is one nut in the back of the motor mount, and one bolt off the front, and it will tip up enough
Anonymous
  • 35 Answers
  • Posted on Feb 19, 2010
SOURCE: replacing snowmobile track slides for 94 polaris
remove the screws from the front part of the rail that holds the hifax on, then slide it backwards through a window in the track, same procedure on instalation
Anonymous
  • 46 Answers
  • Posted on Jan 06, 2011
SOURCE: polaris snowmobile spark plug wire replacement
THEY ARE THREADED ON . TURN IT COUNTER CLOCKWISE TO REMOVE IT AND CLOCK WISE TO INSTALL IT
Anonymous
  • Posted on Jan 14, 2013
SOURCE: I have a polaris 2009
how do i hook up a HID kit on my sled?
93 xlt 580. Only runs on 2 cylinders sometimes at cold. Change plugs and works sometimes.. Not always same cylinder.. Any way to check stator,coil?
Ask The SnowMan Your Sledding Questions Answered: Off ...
www.off-road.com/.../ask-the-snowman-your-sledding-questions-answer...
Mar 1, 2009 - Its a 96 polaris indy xlt 600 triple not the special edition though. ... THEM SITTING ON THE HEADS BUT ONLY 2 CYLINDERS ARE RUNNING WHEN ... Q: I have a arctic cat ext580 the compression in both cylinders is about 70psi .... i have a93 polaris 600 xlt and I just got home and the antifreeze is ...
93 XLT Carb settings? - Snowmobile Forum: Your #1 Snowmobile Forum
www.snowmobileforum.com/polaris.../41045-93-xlt-carb-settings.html
Nov 27, 2009 - I bought a new to me 95 polaris sport last year. it had not run in twoyears. ... It's all in the tuning, clutching, jetting and gears.. i have a 93 xlt 580 and i ... he is loading up with fuel and just cutting the spark out of a cylinder.. i had ... XLT w/ Triple Pipes Question?
May 8, 2013
93 XLT Ran Great, Shut Down, Now Backfires
Feb 13, 2012
Dead cylinder
Dec 11, 2011
1998 ski doo f3 700 wont run right
Feb 22, 2011
More results from www.snowmobileforum.com
Polaris Indy 600 XLT HELP! - Snowmobile Fanatics
Can the timing be set on a 2012 polaris 550 snowmobile
no. and you should not need to. Just reassemble and it will be set.
Polaris snowmobile
Sounds like the engine wasnt flushed properly.
2answers
Trying to locate plug-in on wiring to speeo sensor on 2007 polaris iq touring 600
The Input is there but you are receiving input voltage that is throwing off your gauge. That wire is what you need to find... Somewhere you need to find the chaffed wire
Spark plug removal on a polaris 750 IQ touring snowmobile.
May 01, 2017 • Polaris ATV
I have a 1996 polaris xlt with weak spark. I put
you just make a ground, and pull the engine over, if it is weak spark all the time, it is probably the coil, there isnt a meter, its just feel, if its running like ****, replace the coils and see what happens, this happend to me
7helpful
2answers
Horsepower output from a 95 polaris xlt 600 snowmachine
A 1995 Polaris XLT 600 snowmobile has a class-leading 120 hp.
Replacing snowmobile track slides for 94 polaris xlt sks
Top Winter Sports Experts
Arnie Burke
Arnie Burke
john h
ADMIN Andrew
ADMIN Andrew
Are you a Winter Sport Expert? Answer questions, earn points and help others
