To reset your password on a computer, visit www.blackberry.com/blackberryid. Click Reset your password. ...
To reset your password on your BlackBerry device, when you are prompted to sign in with your BlackBerry ID, click Forgot Password. Answer your security question and complete the instructions on the screen.
Hold the home key power and volume down sometimes it its up so try both ways if not go on u tube they have a video on how to do it just type in how to master reset and what your phone is and your good to go
SOURCE: Anti-theft
no way around this.the vehicle will not start without proper signal from pats key.if your using the same keys you always use there must be a problem with the passive antitheft system.but if you or someone else have attemped to start the vehicle with a key that is not programed to this vehicle the antitheft will kick in and you might have to have get your vehicle scanned and the keys reprogramed.you could try disconnecting the battery for at least 10 min this will clear the memory,then try to start.if still does not start there is a problem with antitheft.
SOURCE: anti-theft system activated need info on to
all dash lights keep coming on and either stay on or flash until you step on brake....also the dinger keeps dinging until you press on the brake.....we have had a tech work on it but have no idea whats going on.....HELP
SOURCE: Anti theft activated-now car won't start and radio
to turn off the theft system, all you have to do is put the key in the door lock and lock and unlock the door, this shuts down the anti theft system,now this has nothing to do with the radio, the only way the radio would ask for the code is if it was removed or the battery unhooked,anyway try the unlocking of the door even try the passenger door, hope this helps.
SOURCE: The car wont start, the
TRY REPROGRAM KEY .PUT KEY IN IGNITION SWITCH TURN IGNITION SWITCH ON POSITION 20 SECONDS DONT START ENGINE WAIT 20 SECONDS TURN OFF SWITCH THEN TURN SWITCH BACK ON 20 SECONDS WATCH THE THEFT SECURITY LIGHT BLINKING.WHEN THEFT STOP BLINKING VECHICLE WILL CRANK.IF LIGHT STILL BLINKING.TRY FEW MORE TIMES KEY IN SWITCH ON POSITION FOR 20 SECONDS.MAKE SURE YOU HAVE THE CORRECT CAR KEYS IN SWITCH IF NOT WRONG SET OF CAR KEYS WILL SET OFF THEFT SECURITY SYSTEM.IF KEY RESETTING TRICK DONT WORK.CHECK BATTERY POWER MAKE SURE YOUR BATTERY HAS 12.5 VOLTS AND CHECK SECURITY THEFT FUSE.IF ALL LOOKS GOOD YOUR SECURITY HAS TO BE CHECKED OUT AT THE DEALERSHIP.
SOURCE: anti theft device
quite easy take the door panel off and look inside ,now dont quote me here but i think the switch part isnt turning all the way to release the alarm ,its turning one waybut not the other ,maybe a drop of engine oil squirted up behind the mechanism wll cure it as it often does for me .
If you forget the
password, delete it using the fol-
lowing procedure and set a
new password.
p { margin-bottom: 0.21cm; }
1 You can only use the
buttons on the projector
to delete the password.
2.The password cannot be
deleted using the
above described procedures
while the "Anti-
Theft" function is set.
If you forget your pass-
word while the
"Anti-Theft" function is activated,
