Ad opens as sokn as I start to use tablets, they also pop ove anything I am doing from time to time. Have search and tried everything I canthink of. Please help, driving me crazy . Thanks Ann
SOURCE: Crazy Tablet - Genius 8x6
I have same tablet and the biggest problem is USB cable!!!
USB able is made from bad materials and the plastic/rubbery coating of inner wires of USB cable is very easy to brake, then the wires inside of the cable get connected between them selves and all the problem that you have starts.
I had those problems and all was solved by changeing the USB cable.
Changeing the USB is litle bit problematic becous it is connected to the tablet by microconnector that is wery hard to find (for me it was inpocibile). Becouse I couldn't find the matching microconnector I connected new cable to the one on the old cable welding the wires to the ones on the microconector . AND IT WORKED!!!
You may consider to by new tablet becouse this may seam complicated, but for me it was an interesting thing to do and it payed out. Just watch out to connect all the wires properly!!!!!
I hope this was helpful :)
Sorry for bad english ;)
P.S. If you have any problem while doing this write me here and all try my best to give you answers.
Steve from Serbia!!!!
SOURCE: Cant open configuration for wacom tablet
if you're using windows XP (like me), try this:
open the configuration window, at least as far as possible. then enter the task manager, right click the wacom tablet configurator and choos "maximize". no perfect solution, as you have to do it everytime you want to change something, but still better than nothing.
SOURCE: Pen Status window stalled during installation.
the software update is different.
look also for the latest update for the pen
this wil solve a lot
SOURCE: my craig tablet keeps coming
Low memory for android process. Update slideme from www.slideme.org and then install eveything on the micro sd. Let the tablet memory free for process. I know this because a got the same tablet with the same problemm until this. First return the tablet to factory default
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
