SOURCE: Wiring help please
The blue wire is usually the remote turn on source for an amp or power antenna. The orange is usually an illumination wire to brighten or dim the display of the unit.
SOURCE: hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
SOURCE: wires from the wall are
Take a look at this image:
Notice that the Line 1 will typically present on pins 3&4 and Line 2 on 2&5. I would think in your case Black/Blue is Line 1 (3&4) and Yellow/Black is Line 2 (2&5).
If you have a 1 line phone and only have 1 line active, then typically blue and blue/white can be connected to the Blue and Black of your Jack. If this doesn't work, switch with the Yellow and Black.
Please let me know if you have further questions. Good Luck!
SOURCE: Does CPLE18-1B unit revering valve needs to be
the easy way to check this is . turn the fan to on ... next on the unit outside turn the power off take the orange wire off turn the power back on and run the unit and see what happins if it cools with the orange wire off then hook it up to term o . if it heats with the orange wire off hook it up to o .
