My Zanussi washing machine with 7 years under its belt suddenly stopped working. On checking the forum found that it might be the brushes. I found that they were worn out, so I replaced them, and the machine now works perfectly. A new problem is that the motor gets very hot, and gives off a hot burning smell. What can this be? Any help, please!
SOURCE: Vacuum motor shaft too hot
Check the brush roll ends, will they turn easily or is one frozen. If so, you need to replace the brush roll. If the motor turns on, it and the belt are trying to turn the brush roll and can't. Also check the ends where the brush roll sits in and make sure it hasn't overheated and melted., If it did you will have to replave the base.
SOURCE: burning smell
Unlock the sweeper brushes and take them out. on each end is a cup bearing and should be free of debris.
then check around and under the belt and likely there is debris wrapped around it.
the post is getting hot as your pulling too much of a load.
though if it continues the motor may have a bad set of motor brushes (inside the motor) or bad wiring (kinda unlikely).
SOURCE: Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
SOURCE: Sebo x1.1 - burning smell
Try replacing the belt. My vacuum cleaner had the same problem and once the belt was changed the burning smell was gone.
SOURCE: Electrical Burning Smell from Henry HVR200 Vacuum Cleaner
Hi! Highly unlikely that you need a new motor. Highly likely that you need new carbon brushes. The smell is caused by excessive sparking between the worn brushes and the copper commutator segments. Most carbon brushes (and from memory I suspect this includes Henry's) have a copper wire buried in their last few millimeters, and you really need to change them before that becomes exposed. The longer you run it like this, the more likely you are to damage the commutator, so change them sooner rather than later. When you change the brushes, you can smooth off the commutator with very fine abrasive paper (the objective is to smooth it, not scratch it!), and then blow all the dust away (or **** it away if you have another vac, of course). Incidentally, you don't say if you are using a paper bag in your Henry. Some people, because the top-hat filter is so good, try to manage without a bag. This is false economy! You should always use a bag. I hope this helps! I value feedback, so please remember to rate this response.
