Garden Logo
Christine Denman Posted on Nov 17, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whenletting clutch pedel out motor stops also egaging cutting deck
free again
Level 2:
Champion:
  • Expert 215 Answers
  • Posted on Nov 17, 2018
free again
Expert
Level 2:
Champion:
Answers
215
Questions
0
Helped
28729
Points
456
Check the tension on the belt and also under the deck for anything blocking the blades from turning
1 Related Answer
Anonymous
  • Posted on May 22, 2009
SOURCE: motor dies when engaging the cutting blades
I need help with this exact same problem. Someone please answer this question.
Whenletting clutch pedel out motor stops also engaging cutting deck
if motor not running correct --tune up ----if runs correct check safety switches and pulleys for failure
Nov 17, 2018 • Garden
You have to press the gas as you let off the clutch or it will kill the motor.
2answers
When I turn on the mower deck the amp gauge starts to discharge and the mower blades stop
There is an electric clutch that engages the mower deck and it (or something in the wiring to it ) is shorted out and you will need to repair/replace it.
Or something is moving when you turn on the mower deck and shorting out a wire. Look closely at any movement occurring near any wires and I think you'll find your problem is a cut/bare wire.
You can cut and then splice the wire back together or just wrap it with electrical tape if the bare spot is not too big. Try to re-route the wires away from the pinch/rub point
Sep 16, 2017 • Garden
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 • Garden
The deck blades stop turning in reverse unless switch is pulled.
This is a safety feature that is not that hard to do so i say live with it.You do'nt have to hold it up just pull it up before you start backing up and once your moveing you can let go without it shutting off the deck until the pedel returns to neutral again,all tractor have it by law after a certain date so jumping around it is niot a good idea.
Nov 30, 2009 • Garden
5helpful
When I engage the PTO, the blades don't egage.
The first thing we need to to do is verify that there is adequate /(power 12 vdc) going to the electric clutch, you can do this by unplugging the clutch and check both wires 1 should have 12 volts and the other wire shoud read infinity to ground if this checks out replace the clutch, if you dont have 12vdc to the wire replace the relay
Engine chokes & dies when deck PTO engaged...
you need to start with your electric clutch and then backwards to your idler pulleys and deck spindles and bearings.
your electric clutch should almost stop the blades instantly when disengaged ,check the center bolt in the clutch to be sure it is tight also
remove the belt from the electric clutch and energize clutch any noise? sometimes the bearing goes bad in the clutch itself.
check all of your 3 spindles for noise and loose. remove belt and spin by hand and listen for quiet and they should turn free with no binding
check blade tightness
any item the belt goes around needs to be looked at for secure and operable.
Clutch not egaging with basket for my profile harmony washer
If you are getting the message " The clutch is not mechanically engaging with the basket properly " the service manual says to check wiring connections, clutch motor or inverter board.
I rarely see a wiring issue. I'd check the clutch arm and clutch coupler too. They are nylon parts. I'll send you a couple pages from the service manual as soon as I get a chance to scan a few.
Top Garden Experts
Jay Finke
Jay Finke
john h
