Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
