Washing Machines Logo
N
Nikki Posted on Nov 12, 2018
How to fix my haier washing machine? Not doing the final spin at the end of each cycle? Any suggestions?
Donald Hedger
Level 1:
Habit-Forming:
New Friend:
  • Contributor 11 Answers
  • Posted on Nov 13, 2018
Donald Hedger
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
11
Questions
0
Helped
11565
Points
18
5 Related Answers
Anonymous
  • 1294 Answers
  • Posted on Jan 06, 2008
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
A
Anonymous
  • Posted on Sep 06, 2008
SOURCE: bosch wff 2000 washing machine - won't spin/drain
I had a similar problem a few years ago, sometimes it would pump out sometimes it just stopped and would not spin. Turned out the pump was broken so I replaced that and everything has been fine since. The guy in the spares shop told me it was not uncommon and showed me how the impeller could stick to the casing magnets. The pump cost about £40
docjohn174
john gagnon
  • 943 Answers
  • Posted on Oct 04, 2008
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
Anonymous
  • 3 Answers
  • Posted on Mar 04, 2009
SOURCE: Spin cycle error - UNB
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Jeffry's Appliance Service
  • 254 Answers
  • Posted on Mar 17, 2009
SOURCE: How do we fix a washing machine that does not spin?
Is it agitating? If so you may have a bad lid switch if it's not spinning or agitating you may have a bad drive coupler.
Haier top loader Model HWMP65-918 Machine will fill, go through all cycles, spin and drain. It wont agitate/ wash the clothes
Try a power cycle before replacing any parts. You can also turn your dial counter clockwise and retest the wash. Otherwise, I would suggest setting up an appointment with home depot to get a full list of parts that need to be replaced in your washer.
Thank you.
My Haier portable washing machine wont do spin cycle
If resetting the washer doesn’t work, the limit switch may be stuck. The sensor for a unbalanced load is a limit switch. The switch should snap back into standby position when the wash tub comes to a stop. Sometimes the switch will stay stuck. Move the barrel by hand back and forth until it hits the inner walls of washer. It may knock the switch back in place.
1helpful
2answers
Err02 shown during spin cycle on 1400 haier washing machine
WHEN I INVESTIGATED FURTHER I FOUND THE DRAIN TUBE FROM MACHINE WAS BLOCKED BY SOLID SOAP LUMP BUILT UP AT THE MACHINE END -AMAZING .
1helpful
2answers
Haier XQBM22-C washer stopped spinning
It still doesn't work! I don't know how to fix it.
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
