Does anyone know how to bypass the HDD/SSD password on a toshiba laptop. I have tried all the various ways of bypassing the user and admin password, but nothing bypasses the HDD password. Toshiba charge excessive fee for this repair, and I believe it’s their fault . Even removing the hard drive and putting it into another machine won’t allow HDD access. No password was ever set for this, it just appeared one day and not been able to use it since. Thanks in advance.
Others have been able to change the password in BIOS. Found this:
1. The HDD password cannot be removed using Security Assist.
2. Using SETUP BIOS (i.e. start machine; Hold Esc; Press F1), Tab to the HDD Password section which should be displayed as follows:
HDD Password
HDD = Built-in HDD
HDD Password Mode = USER Only
User Password = Registered
3. Tab to the "User Password" field and simply enter the old password and then a new one twice (once to verify) as one would do normally. If you don't want a password, just press "enter" twice
he said he lost the HDD PW or was set buy others. (BIOS+SED)
he is asking how to get data off a SED drive.
changing PW A to PW B is NOT his question
the HDD is PW locked, !
The BIOS stores the AES 256 key, so that too is lost. (both BIOS and SED lost keys)
only that is the topic,
and is impossible to fix,
but no HDD model told so....
the word excessive is not true at all
if the hDD is bricked and the mobo
that will be expensive.
add to data loss, more.
always backup
and do not use BIOS or HDD or SED passwords
unless you have your act together, that most do not, including ME,avoid it if wise.
lets say you bought new, (did you, unsaid)
if yes, and was REALY NEW>
then later (NO PC stated, so answers will be wrong, even MINE.
but years later if the RTC coin cell battery expires,(dies) the BIOS then can not let you
access the HDD, this is normal for batteries dead, the BIOS configurations are lost
(easy fix)
but now it can NOT unlock the HDD (fips?) password in this state.
The cure is easy replace all bad batteries
some RTC batteries in SOME Toashia's are not really a $1 coin cell,
but is in fact a larger, NiMh rechargeable. battery inside, some have this and 1 more coin.
so no PC stated, is big failure here on your part, (learn that technology change by year and by model)
if you read your manual
it says, turn PC on, leave it on for 12hours
so all rechargeable batteries for sure the
RTC NVRAM battery charges
if step 1 , remove huge battery first cases PC to run ok, then run it like that forever
or buy new one.
also this PC may have BIOS bug related, some do and only Toshiba can help there
we are NOT THEM.
next time buy DELL or HP.
in all cases, of any Laptop the shop
checks all batteries first he tests them.
OK,. power is first always. in electronics
and no noise from them. (bad AC pack)
how the password works is key to why.
the PW for BIOS gains you access to the PC (BIOS access)
then the BIOS holds the HDD 256bit HDD Hencryption key, and then unlocks the drive
using that key
if the batteries fail (up to 3)
the BIOS thinks its being hacked and blocks you. that is the pure logic of BIOS reasons.
The BIOS and HDD, are married,
see? this means if any part in the chain,,fails, you are blocked.
see hacking it wakes up and blocks you.
this can happen with bad batteries, easy.
so test them and charge them if that fails replace them.
one common problem is parents letting children play with there PC,
and they play in BIOS bam, you be here.
so keep kids way, buy them 10 year old PC.
let them kill it.
as you can see the RVram battery is run by NiMh and is soldered down
that is why pulling ac POWER AND BIG BATTERY DOES NOT RESET THE nvraM SO THEREFOR NO PW IS RESET.
THE HACK IS 2 FOLD.
UNSOLDER THE BATTERY AND PUSH POWER (N0 ACPACK BIG BATTERY THERE)
AND NOT ALL CAPS INSIDE ARE ZERO VOLTS.
NOW WAY SAY A DAY (AS PURE INSURANCE)
NOW TINY BATTERY BACK
ac PACK ONLY THE BIG BATTERY IS JUNK PARK IT ON A SHELF AN FORGET IT.
now see if it powers on. ok.
the video is for shorting the power feed from that NiMh battery and is really bad idle. (shorting any battery is bad idea)
but is all part of the hackers mentality.
"anything goes"
A USB/SATA jump cable to connect it as a slave drive will access files on it but not accounts it is logged into.
$25-35 and the best piece of hardware you'll ever have for a computer
true for some but not FIPS Drive.
the drive is 100% locked for ever.
by DESIGN.
as you see the HDD does not work in any PC so will not work on the cable adaptor
either for the same reason or direct connect to say a real desktop PC (fails)
FIPS, FIPS makes the drive dead.
the purpose of FIPS is to end that HACKING.
Fips ends this practice (by design)
Read about SED, self erase too.
but no HDD model stated by OP even when they removed it they failed to read the label and
tell the model number here.
just that alone tell me what is possible.
the answer is NO.
FIPS drive, used
FIPs + TPM + UEFI, means NO;
by design, read the spec. it is clear.
best don't use it.
unless you work for DOD/CIA/NSA or the like and must.
ok>
read this.
as they bounce about, the word is NO.
folks can not come to grips on
that is how it works and on purpose.
and by DESIGN.
http://www.tomshardware.com/forum/id-180...
the only path that works is secure erase(SED)
if you can do that, and remove the password,
the drive can be moved to a 2nd PC
but you will never get there.
not only that there are other tricks in the mix. (if the firmware in the HDD thinks it is being hacked,... Read the spec...
since you forgot the hDD PW
you can't do that
for others reading here and want to kill FIPS dead, now, read the above posted link,
if you ask the OEM of your PC, how to do this
they refuse to even talk about FIPS
(oem lawyers, rules)and new GDPR rules (and NIST)
the might say, do not turn it on day 1 new
and end the discussion.
one guy in this Pickle.
showed his Invoice to DELL.
and 10 hours on the phone, no fix.
and was a wasted effort on both parties.
all needs be said
"if you can't guess" the PW the PC is bricked
on some the TPM bricks the mobo.
now we know how Hillary lost 30,000 emails
LOL !!!!!!!!!!!!!!!!!
NO PC even stated nor OS.
but the older Toshibas before w8
had bug in bios.
https://www.youtube.com/watch?v=b2OFUsEB...
this video makes my eyes hurt
but shows a hack that works
and also prove the BIOS is faulty
and proves one can hack the early versions of this horrible FIP, BIOS on early PC.
I think in that shaking video mess he is flashing his BIOS then putting back the HDD.
good luck but do know this?,
that hack above only works on older PCs
and only not updated.
ok?
no HDD stated.! it has label read it, and tell what you read, PC get HDD or SDD upgrades all the time, some of min 3 or more times !
older HDD.
some can be attacked on old non FIPS drives.
the old drives, are weak.
the can be hard reset and dictionary attached, until cracked, might take a year, but sure.
FIPS ends that way.
ok
and this PC has bugs, in the BIOS>
good luck cracking this. (fail)https://www.seagate.com/files/www-conten...
some hhd have SED, secure erase
and some have automatic SED that erases the drive, if hacking is detected.
YMMY , your machine may vary.
moving the SED drive to PC #2
how can the 2nd PC know the 256bit key
it can't.
SOURCE: don't know HDD #1/SSD #1USER PASSWORD ON MY TOSHIBA
Lost Windows password:
SOURCE: Toshiba Satellite Pro A200 BIOS Password Request
for removing the password,
you have to open the memory cover and remove the two RAM s,
after that remove a black or whit plastic film depending on your model, you will loacte for B500 marqued ( XXX ) or J1 you have at least short
the two point with a flat screwdriver and put the upper memory and power on the laptop will holding the screew driver till you see the toshiba screen, if it doen't work just try again. it works 100%
SOURCE: I have a Toshiba studio 281c, we forgot the ADMIN password, help!
the default password should be "123456".
If u did changed the default password, then u need to enter setting mode 08 - 263 to check or edit the password.
SOURCE: How to bypass bios password on a Toshiba Satellite 1305-s6858
the bios password is a tough one,
once i took out the bios password component, and it worked , but very small solder joints there
HDD Password
HDD = Built-in HDD
NO PC stated at all.
NO OS stated, (garage sale PC and unknown sure)
NO HDD model and makers name stated.(label)
NO screen shots posted on the locked screen
never post lacking such key facts
or expect answers to be wrong.
we can not see your screen, so post it.
use cell phone camera and do that,first.
ok>?
other questions not answered yet. all key.
did you buy it new.?
did you loan it to others.
did others play with your PC, ever, kids??
The PC came new unlocked, as all PCs do.
and anyone can change that, when you are not looking, so someone did. that is a fact.
it needs service, by person with
eyes,
hands
and skills.
we can in fact advise tests, to do
I see you have tested that HDD,
and if it is locked you will never get It unlocked, if guessing fails.
by Design, this is what it does, and does so perfectly.
Even the CIA uses this, and trusts it.
Go to any HDD makers web site,
WD or Seagate are 2.
read how this technology works, now.
it is UNcrackable.
some even BRICK the DRIVE of you are caught
trying to hack It 3 times or more.
some even auto Erase the drive as the hack protection.
learn this, and keep others away from you PC.
or bad can happen
stay backed up too.
Buy a new HDD, there is no other way.
Buy SSD is better, and very fast.
if PC has m.2 slot, even best of best this.
even buy a DRIVE with no bitlocker..
bitlocker is MS product.
here is seagates version
https://www.seagate.com/tech-insights/pr...
see how autolock works, etc.
You will need to buy a new HDD if locked.
In fact this feature assures that by design.
if the PC has a Toshiba HDD with MG,MK or MQ prefex in the partnumber and FIPS compliant.? and sercure erase , etc...
and that is activated. ?
you will not get the drive to work. ever.
this technology is covered here, if you want to learn.
https://toshiba.semicon-storage.com/cont...
Thank you all for your replies to this, you have been very helpful, although there is no solution.
Sorry for the lack of info in the original past, but I have been trying for several weeks now going through numerous different methods to try and bypass this hard drive password.
I had also contacted Toshiba helpline as well and spoke to them for some time on the issue.
I am no longer looking for a way to bypass this, I have ordered a new hard drive, and will reinstall windows on it, as it is the cheapest method to get laptop working again.
In case anyone else comes up with the same problem in future, (believe me, there are thousands already) I will explain what I have found out.
First off, the only way to get pc/laptop working if it asks for HDD/SSD password, is if you know the password, and I would presume that you set the password.
If you did lot set the password, like me, and thousands of others, you can forget using the drive again, or send laptop back to manufacturer, where they can fix it for you, for a price around about the same as a new laptop. After all, it is them who place the software onto the drive. The software operates if it thinks the laptop has been stolen or hacked into, just how it works, I don't know, but it stops access to the drive, until password is input at startup screen.
Sending it back for repair isn't as easy as it may sound, you have to prove you are the owner, show receipts and such before they will accept it back. Definitely not an easy task.
This password setting like thousands of others set itself on my laptop after it lay for a couple of months, and battery went completely flat. I recharged and started it up, only to be met with this password request.
With the Toshiba laptops, it is impossible to crack the password, and even putting the drive into another laptop and a pc, it just wouldn't allow access to the drive, although the drive did show up.
I hope this helps others out, and Save's them a lot of time and effort to get nowhere. Just how the software enabled the password on my machine that has never been stolen or hacked, as it isn't even a year old yet, is beyond me.
http://pcdied.com/passwords.html#bitlock...
your HDD , No model number stated,
my be the Toshiba MQ Toshiba HDD
with lock turned on. (hopeless cures)
a FIPS drive.
example
MQ01ABU032BW
320mb, (up to 2TB)
read how FIPS works, and secure erase
it is doomed,
ask any shop to fix this
you get charged for.,
new SSD
new OS
and labor. (2hours to load OS, is fair)
there is no need to ship any PC to Toshiba.
millions of repair shops world wide.
find one ask them.
not only that but some Toshiba's have nasty BIOS bug. Why buy this brand? IMO
