SOURCE: Miele washing machine model W713 front load - issues
If it is leaking from the waste pump area it may be blocked by a small piece of clothing like a sock or something similar! This will also cause it to take too long to complete a cycle. Remove the rubber hose onto the waste pump and check inside the hose and the pump, make sure the pump spins freely and that nothing is stuck in the hose pipes leading to the pump
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
You can replace the Bellows as it is called but to fix it before you replace it clean it with Bleach to kill the mold and then dry it ALSO after any load you do leave the door open a bit this allows the mach to air dry out and prevents the build up of mold ..Good Luck plz rate this post for me
SOURCE: miele washing machine wont drain
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
hoses
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
SOURCE: Have Miele G653 SCVi plus. We have inlet/drain flashing red light
Sounds like something is caught in th drain pump as the unit has to drain first before anything else happens. Remove the filter and the non return valve which is under the clip in the sump of the unit. In the manual it shows you this. Make sure the drain pump is free of any foreign particles like broken glass. Then start the unit again so it goes to drain without the non return valve in place. This will then throw out any foreign particles as well.
or it could be the drain pump is activated all the time which is the noise you hear as there is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Testimonial: "Thank you for your excellent advice, the machine was flooded in the base when the panel was removed. "
SOURCE: My Miele CVA620 machine announces 'Expel Air,' and
I'm probably to late for this answer, but I will share it anyway.
I got this problem after buying a used CVA620, that had not been used for a while.
To solve the problem i used a breast pump :-)
My wife had this doublepump after the last kid. And I used the hoses that comes with this unit (rubber-like) and connecting them to the hot-water and the steam-nozzles. I started pumping, and pushed the hotwaterbutton. After 5min of pumping and swearing, the job was done. No my CVA works as a charm again :-)
