Hello, I have a 22 year old Frigidaire FWT445GES0 front loading washer. The outer drum hole where one of the rear suspension springs go through has broken. I do 5 1/2 loads per week and never over fill my washer. My Warranty Company does not want to pay for repair/replacement telling me that it because of user negligence. Please help me deal with the Warranty Company. If I can somehow prove that this kind of breakage can be caused by normal wear and tear.
SOURCE: Washer drum tilted
if possible change all three ..probaby right rear but others may now be stretched
SOURCE: ford escape Rear Suspension With Coil Springs - out of joint?
It is a 4x4. The "yellow" looking item in between/inside the black spring coil seems to be out of its joint. When I compare the left vs the right, the left side is sitting up high, while the right side appears to be settled into place.
SOURCE: Front NS Suspension Spring Dislocated
dave you must have a broken spring and will have to remove the strut to fit a new one dont drive with it like that. no special tools needed goood luck
SOURCE: front load washer loud noise and drum loose but not dropped
Spider arms attached to stainless steel drum inside of tub have probably broken. This is a known problem with Frigidaire front loading washing machines. The stainless steel drum has a 25 year warranty but this does not include the spider arms. You cannot buy the spider arms separately, you have to buy the unit as one. The drum cost about $250.00 and probably about $300.00 in labor to install. You can do it yourself but it is pretty involved. Good Luck!
SOURCE: frigidaire front loading washer CRTF1240A won't turn/spin
I had the same problem, we opened up the bottom front panel and found a loose connection. Electrical connector had shaken loose.
