When camera switched on the message Camera error code #803 comes on with See user's guide. User guide says call Kodak who doesn't respond.
SOURCE: error code e30 see user guide .comes on and stops washing do not have user guide
E30 is a motor problem which is most likely brushes need replacing.
Hope this helps & Thanks for using Fixya.
SOURCE: Kodak Error B03
Either your PCB board is damaged, your batteries are old, or your AC adapter is providing higher voltage than the required 3 volts.
SOURCE: i have kodak ls443 get error message camera error
Hello
Firstly, at the link below you can download a updated softcopy of the manual for free.
http://www.retrevo.com/s/Kodak-LS443-Digital-Cameras-review-manual/id/200dj378/t/1-2/
As for the error code you are getting, "error 45" is a lens related problem of LS443.
If the lens is not stuck, you may try to download the firmware from the Kodak site and update the one in your camera.
As the lens is already stuck, there is no choice except to send the camera back to Kodak for servicing.
Hope this can steer you in the right direction.
Kind regards
Andrea
SOURCE: My camera will not close, previously would not
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
Testimonial: "Yes, this info was very helpful and accurate. Thanks much."
SOURCE: KODAK Easy Share V530 (Error # E45)
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
