SOURCE: Minolta Di351 Dialta
Try shutting the copier down and then unplugging it from the wall for 15 minutes.
If this does not reset the device, a technician is required.
SOURCE: minolta dialta trouble code c0650
C0650 .THIS CODE IS FOR SCAN MOTOR OR SCAN SENSOR PRBLEM.JUST CLEAN SENSOR OR CHECK SCAN MOTOR IN OPTICAL UNIT.MAY BE MOTOR HAS PROBLEM.BY MIAN JEE
SOURCE: MInolta Di 183
Abnormally high toner density detected Black ATDC (auto toner density control circuit)
Replace black IU, check toner motors, make sure toner is loose not clumpy. Change dev reset toner level.
Thanks.
SOURCE: caro esperto codice errore c0510 minolta dialta di
Amico C0510 - fusione fallita (temperatura di fusione del basso anormale) temperatura del termistore fusione roll undectable rimane al di sotto di 120 ° ... controllare il fusore
SOURCE: konica minolta di 1611, di
Hey all, after a load of grief, and NO help from the INTERWEB, I have chanced upon a solution. Firstly I installed a new local printer with IP number for network printer and associated network address/port (\\server\konicami). Then I installed the win7 64 bit bizhub162 drivers. Then I installed the win7 64bit BH 164 drivers and put an additional driver of BH 164 x86 win2000 on the properties (server has win2000). Then, when I selected the BH162 driver in printer properties driver pull down menu, it worked. wahey.
