Posted on Nov 05, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Emerson 303TT cassette tape turns but no sound
Russ Hill
Level 3:
  • Emerson Master 4,057 Answers
  • Posted on Nov 05, 2018
 Russ Hill
Emerson Master
Level 3:
Answers
4057
Questions
10
Helped
1177542
Points
12696
Try cleaning the head reader as this reads sound and also controls speed ( cotton bud with rubbing alcohol or audio cleaner) . if the speed is steady i.e going round at the same time it's the amp chip is damaged as its receiving a signal from the tape for speed control.
1helpful
Can a CD be burned from an audio cassette on the Emerson nr303tt
No. A CD can be burned from cassette tape provided you have a quality cassette deck, computer cables and software.
Emerson NR 303TT Table only turns when the tone arm is in one spot
There is a mechanical switch inside the unit. You will have to open her up and reposition the switch.
I have an emerson euphoria am/fm stereo radio/cd player/cassette recorder. i want to record on cassette. there are 6 buttons with symbols on them. what are they and which do i use to record
the standard tape symbols are as follows.
triangle on side pointing right - play
filled dot - record these need to be pressed at the same time.
while recording
II symbol is to pause
square is stop.
double arrows left is rewind
doubble arrows right is fast forward.
arrow up with a base is eject.
2answers
CASSETTE STUCK IN VCR WONT EJECT I TURN VCR ON IT STAYS
turn on the machine. use your figure push on the cassette, when you feel the cassette can't go any farther (don't jam it),and hold it there. press the eject button, you may have to try this couple of times in order for the cassette to come out.
the cassette deck need to have the drive belt change.
When the tape has been removed the carriage deck will still be in the wrong position. The cassette tray has to be aligned so that the timing of the tape will detect that there is a tape in the machine. At the moment your VCR thinks there is a tape still in it because the cassette tray is not in the full eject position. This can be fixed by a service technician.
Eats my Cassette Tapes
Ok sound like the play head is out of a-line ment - easy way to fix if it is this - remove from the mains supply and open the cassette deck door - press the play button down and look at the play head there is 2 screws 1 either side 1 is fixed and 1 is sprung - now inset batterys (much safer) - try and fit a cassette in without using the cassette door should just fit in then press play and ajust the Right hand side scree with a small screwdriver (insulated) and ajust slightly to the left or to the right and this should fix the chewing - to get it just right use headphones ajusting left to right will tke the sound + & - to each earphone. Warning dont turn to far to the left as this will undo the screw completely - u have a least 1 whole turn either way is fine
1helpful
Emerson vcr won't accept a tape
Yes, it can be fixed, but the cost may not be worth it.
There are several components which may be the problem, ranging from a gear, a sensor, the load motor, or it may even require replacement of the entire cassette loading assembly.
Without an inspection, it's impossible to tell exactly what the problem is, or likely cost to repair.
It may be much cheaper to replace the machine.
2answers
Cassette Recorder play problem
Sounds like the tape tension sensor is stuck. The sensor is always telling the mechanism that the tape has reached the end.
3helpful
3answers
Tape won't load.
This is a problem with the process called 'tape loading' - pulling the tape loop out of the cassette and wrapping it around the spinning video drum, engaging the capstan and pinch roller and reel rotation. With the cover off, observe the behavior when you hit play. (You may need to put a piece of cardboard over the cassette to block external light from interfering with the start/end tape sensors). Assuming this is a basic VCR (no instant start features), you should see: 1. The video head drum begins to spin. 2. the roller guides move smoothly on the tracks, wind the tape around the drum, and stop snuggly pressed against the 'V-stopper' at the end of the tracks. 3. The pinch roller moves into position and presses the tape against the capstan. 4. The tape begins to move and is wound up by the takeup reel. 5. The picture and sound appear on the TV. With a 'rapid or quick start' (or it may be called something else) transport, the tape moves to a half-loaded position when the cassette is inserted. This is at an intermediate position partially pulled out of the cassette but not wrapped around the drum. On VCRs with a real-time counter and/or index search capabilities, the tape will be in contact with the control head. With an 'instant start' transport, the tape will fully load around the spinning drum when the cassette is inserted but the capstan will not engage and no tension will be applied to the tape until you press PLAY or REC. (After about 5 minutes, the drum will stop and it may unload to the half loaded or unloaded position.) Note that for VCRs with a real-time counter and/or index search capabilities, the tape must be in contact with the control head (but not the video heads) for all relevant modes. These VCRs (which include many modern units) must therefore pull the tape at least partly out of the cassette. In all cases, the completion of the sequence results in approximately the same mechanical configuration during PLAY. Several likely possibilities when it shuts down: 1. Everything occurs as above, picture and sound appear for a few seconds, but then the VCR unloads the tape, ejects the cassette, goes into REW mode, stops, or shuts off. Two common causes: The takeup reel does not turn and tape spills into the machine. This is sensed by the microcontroller which aborts record or play and attempts to save your valuable cassette. Most likely cause: old/dirty idler tire. As a test, turn the idler tire inside-out. The fresh surface will now work well enough to confirm this diagnosis and will continue working long enough for your replacement idler tire to arrive. See the section: "General guide to VCR cleaning and rubber parts replacement". The takeup reel is turning properly but one of the reel The takeup reel is turning properly but one of the reel rotation sensors or its electronics is defective. As a test, check to see if the tape counter is changing at any time during the loading and
Top Emerson Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
