A detailed description of this procedure is found in the manual of your watch. You can find the right manual with the module nr. on the back of your watch (4 digit number in a rectangle)
The manual for your watch can be downloaded via the link provided below:
Timepieces Watches
SOURCE: Can't adjust the date on a digital watch
These are the instructions for the AD0721. They might apply to your model, too. I hope this helps:
http://img261.imageshack.us/img261/6784/manualr.jpg
The analog setting of the watch takes place by pulling out the knob (kind of tough) and adjusting, like a regular analog watch. The analog and digital displays are will NOT stay in sync, unfortunately.
Good luck.
PC
SOURCE: I want to set the time
press the mode button until you get the time blinking then press the alarm button thrice and you will get the date and now you can set it
SOURCE: adjusting Date and day on a Festina 3 dial watch
Alhamdulillah, the problem solved (at last) tks to IRONMAN
(http://www.fixya.com/support/t579677-instructions_mens_festina_watch_16095#SameProblemContinued)
The steps are like this :
1. Pull the crown full, and turn it clockwise until you find the right day.
2.
and then push it one click (dont push it to hard so it back to normal
position) and turn the crown counter clockwise to adjust date.
3. Push the small button near the crown to adjust month.
and voila... the problem solved
SOURCE: SET THE TIME ON MY TOZAI ALARM CHRONOGRAPH WATCH
Here is a copy of the instructions.
http://www.tissot.ch/virtualdata/usersmanual/138-en.pdf
Also a Youtube link that will help if your not clear. This one is best shown how as opposed to me typing.
http://www.youtube.com/watch?v=jm73y5o-Fqw
SOURCE: Setting alarm in F5015D F1 series watch
ypu can get a set of instructions by going to their web site (www.jacqueslemans.com).
On the left yu will see a menu, click on "instructions/catalogues" and you can download the instructions for your watch.
Testimonial: "I had missed this when visited the website. I was able to locate and download the manual."
Alarm Setting:
1st: Press the mode button to go to the alarm screen.
2nd: Press the adjust button for the time to flash
3rd: (For the Hourly Alarm) You can adjust the time here while it is flashing by pressing the start/stop button. Cycle through this until you have the time you want. The setting will have the P in the left side of the screen for PM (night time).
4th: (For the Daily Alarm) Do steps 1-3 once the time is flashing use the Mode button to cycle through to the date field of the watch. Once it is flashing you can use the Start/Stop Button to chose which date Month/Day, after chosing the month just press the Mode button once more to go to the day field.
