Electrical Supplies Logo
M
Monty McGinnis Posted on Nov 02, 2018
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Garage door remote transmitters quit working? Hard line switch works ok. How can I fix remote transmitters?
Chuck Graybill
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 104 Answers
  • Posted on Apr 18, 2019
Chuck Graybill
Expert
Level 2:
New Friend:
Cheetah:
Answers
104
Questions
0
Helped
40352
Points
206
Since you indicate that two remotes do not work, I am guessing the receiver on the opener is the problem. Verify that connections to the terminals (located where the wires from your hardline buttons are connected) are intact.
5 Related Answers
Anonymous
  • Posted on Oct 29, 2008
SOURCE: Garage Door Remote Not Working Consistently
Lift Master Security Plus remote works only intermitenly, It seems to lock after a few tries, Works from inside garage, Seems to lock up after few tries, Wall opener fine. Changed batteries several times. Can't understand why it works and then doesn't. Tried cleaning sensors and wires,
kninejk
  • 5 Answers
  • Posted on Dec 11, 2008
SOURCE: remotes quit working for garage door
I had the same problem with my Craftsman opener but different model. However to fix this I simply followed the instructions that came with the opener and reprogramed the remote to the opener. The instructions are in your owners manual and are pretty straight forward.. John
Anonymous
  • 3197 Answers
  • Posted on May 12, 2009
SOURCE: Garage door opener remote won't work
meerkat1 your receiver has quit working which is part of the logic board. The logic board runs around $80.00 for the part alone. Might be time to get a new opener.
Anonymous
  • 460 Answers
  • Posted on Nov 15, 2009
SOURCE: my remote quit working. part # 139.53681B. I
the remote that does not work is probably bad.orrr it might need the code reset to match the 1 that works..
Anonymous
  • 3197 Answers
  • Posted on Nov 05, 2010
SOURCE: Our Craftsman Model 139.53684 Keyless
Sounds like your logic board has quit working.
Transmitter quit working for my 3018,I put in new battery??? still lights red led on it but, not open the door...?
Ken, you may have to reprogram transmitter after battery change, check your manual, if you do not have manual, Google search your make and model# manual.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Garage Door Help How to Program Your Garage Door Remote Control
How To Program Your Garage Door Opener
How to program Garage Door Remote change battery LiftMaster Chamberlain
Programming Garage Door Remote DoItYourself com
Automatic garage door not responding to any transmitters
Sounds like you need to reprogram all the remotes. Instructions should be with the new unit and even on the back of the unit up top .I just reprogrammed all of mine. When I installed my wall unit the others quit as well so I reprogrammed them. all.
HOW TO FIX MY REMOTE CONTROL FOR GARAGE DOOR OPENER
Maybe time to change the remote battery? Many remotes also suffer from poor solder joints where the battery terminals are. Check the terminals and re-solder as needed.
Remote and my keypad remote both stopped working as of today
CHECK TO SEE IF THE LED ON THE WALL BUTTON IS BLINKING - IF IT IS SOMEONE HAS PUSHED THE VACATION LOCK BUTTON.
PRESS THE LOCK BUTTON TO MAKE THE LED STAY CONSTANT AND IT IS FIXED.
HOPE THIS HELPS
2helpful
Cannot re-program remote transmitters for garage door opener
If both remotes quit at or about the same time then it is most likely the receiver that has quit. Especially if you have had electrical storms in the area. The receiver is part of your logic board.
Garage door opener will not respond to security plus remotes
Reset the Liftmaster unit. There should be a red reset button on the unit in the garage. If this does not work, reset the breaker. Good Luck!
How to set dip switches on remote for Chamberlain Liftmaster 1000
I would go with a chamberlain clicker on this issue. These remote are phased out and the 9 dips don't work well with them. Thanks BB
Transmitter not working ( 3 of them)
don't hold down green button. push for one second. do yu have console with vacation or lock button. deactivate it.
All garage door transmitter would not work
The lock is probably engaged. Look at the wall button, the green light is probably flashing. Hold down the lock button for 3 seconds and light should be solid. Your remotes should work now
Top Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
