To display Error Code:
Move Programme Selector to the Off postion.
Press the 2 buttons on the right and turn the selector 1 position clockwise and hold the 2 buttons for about 5 seconds until all the lights are flashing. Release buttons and turn the selector to the 10th position. The Error Code will be displayed.
Note the code then turn the selector to off ,then on,then off again.
SOURCE: error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
SOURCE: Washing Machine Fault Code
The recommendation to get a new motor may be overkill and a very expensive option. Also on this site I found an alternative solution which was to just replace the motor brushes. This we did and it fixed the problem, coasting us just £20.15, rather than the £199 quoted for a new motor!
A reasonably competent person needs to remove the motor, identify the brushes and remove - just involves two hex-head screws. When new the brushes will be around 2.5cm long. They need to be around 1 - 1.5cm long to work. Alternatively the spring(s) may be sticking, preventing the brushes from being pushed against the rotor.
When calling suppliers to enquire as to availability I needed not just the product description, but also the PNC and serial numbers (located inside the front door), as types of brushes have varied during the production period. However the outlet I went to still did not have the correct bush - housings were different. The chap serviing very kindly swapped new brushes into the existing housings - this is something you could do yourself if you cannot get the exact same ones - just a little fiddly.
Hope this helps!
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
