Decoder is showing yellow light, red flashing and on the TV its says no signal. The decoder remote doesnot work
  • Anonymous Jan 12, 2019
    im noticed this too please any help? |https://wapnigeria.com/contact-us/
    Top Expert:
  • Televison & ... Master
  • 50,952 Answers
Something inside the decoder has failed.
Posted on Oct 31, 2018
    New Friend:
  • 67 Answers
Try to change power supply of the decoder that is if it cannot even scan. Testing remote control use the camera look into the camera as if you want to take photos of that infra red diode on the remote control then press any keys on it. You should be able to see the diode growing on each stroke.
Posted on Feb 11, 2019
4 Suggested Answers
gdsdolan
  • 5 Answers
SOURCE: sd pvr remote
it sounds like the remote needs to be re-programmed to work with the device. the 2 blinking dots illistrates that it is looking for a device to operate.
Posted on May 04, 2012
gopakumarg43
  • 76016 Answers
SOURCE: My decoder is not responding to my remote. Every
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Posted on Jan 01, 2015
gopakumarg43
  • 76016 Answers
SOURCE: MY dstv DSDD 1132 decoder is flashing red and green lights but yellow light is steady. tv is black and remote not responding
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Jan 12, 2017
How do I clear error BEi or BE1 on dual view dstv decoder.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/..
Aug 17, 2016 | Televison & Video
My decoder is not responding to my remote. Every button I press on the remote, the yellow button on the decoder goes on. Please assist
Dec 31, 2014 | Televison & Video
No remotes work
WHAT WENT WRONG WITH THE ORRIGINSL REMOTE. NEED NORE INFO. If the remotes are not working , is the TV reciving the signal from the remote rather than the remote sending the signal .If the TV is reciving it the light should flash on TV every time it receives a message from remote. if this is not happening it sounds like the decoder in the TV needs replacing / LED might just need cleaning to open access to the sight of view. Jeff
Mar 21, 2014 | Vizio 42 in. LCD TV
Dstv remote not working on any blue dials? Two tv's in separate rooms, one pvr decoder. Only the red dial works on both tv's & both remotes are working & both tvs responding properly.
Is this a newly installed system? If both tv's are responding to the same remote setting (red in case), it means both tv's are set to the same channel. The tv that is connected to the decoder directly (via AV cables, I presume) is supposed to respond to if the remote is set to red. In order for the second tv to respond when the remote is set to blue, you need to tune the second tv until you find the picture of tv2 (the decoder transmits both tv1 and tv2 on the RF/coaxial output and it seems that your remote tv is tuned to tv1 instead of tv2).
Apr 02, 2013 | Televison & Video
I live in Tahiti and have a coship N6760B digital set top box decoder with sky pacific smart card. I have a 2.3 metre satellite dish with Cband lnbf. From the digital meter point of view I got a really...
Jason478. I would be surprised you are picking up the signal from the Spot beam which Sky Pacific uses. I do not believe even the spill is reaching Hawaii. Best to get a refund of your money as you will definitely loose the signal when the replacement satellite kicks in on Dec 2011. Be careful of the Sales people in Sky Pacific. http://www.intelsat.com/flash/coverage-maps/sat_foot.html?sat=IS-701%20at%20180%BA%20E&display=map&spot=0
Jun 25, 2011 | Coship CDVB2000E
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Suddenly cannot record DVD after years
Apologies for the delay in response. Your concern was just brought to my attention.
To your recording, based on your second posting (and would appreciate corrective information where applicable), your system is:
  • Cable provider > Cable Decoder Box > Panasonic DMR-E75V > TV (equipment setup)
  • single coaxial cable > yellow, red & white > yellow, red & white (wiring setup).
With your indulgence, a couple clarifying questions:
  • to watch the Panasonic when you play DVDs, to what channel or source or setting must the TV be set to?
  • to record a TV program/channel, to what channel or source or setting must the Panasonic be set to?
  • what is the brand and model of your Cable Decoder Box?
Initially, pls try:
  • play any known good DVD disc/movie. power on the TV and set to watch said movie;
  • without changing anything on the TV, STOP the playing of the DVD;
  • try changing channel on your Cable Decoder Box's remote;
  • pls post back result(s); or
  • do the above steps again but before changing the channels on the decoder box's remote;
  • try changing/cycling through the different input/source of the Panasonic DVD;
  • again post back result(s).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 10, 2008 | Panasonic DMR-E75V DVD Player/VCR
Televison & Video Logo
2,103 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
