I could not find a manual for your SPW2201SS, but I did find a manual for a SPW2200SS. (Look for clogged hoses, in and out!) Sadly it only lists three 'error codes' on Page 27 and they include: E10 E21 E31 Summit SPWD2201SS Washer download instruction manual pdf
SOURCE: LG Sense Clean DD error code "FE" front loader washer/dryer combo
my lg senseclean wash mashine shows the sign Cl on the display and the door cannot be open what does it mean?
SOURCE: I have the error code 5 on the Ariston washer
hello,
what this mean is that the error code 5 indicates that the water temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F). in your drying machine.
thank you.
SOURCE: My HWD1000 Haier Washer/Dryer combo error EC4
EC4 is regarding: The temperature of air vent.
Within 30 minutes of dry cycle there is 5 minutes in which the temperature is not increasing.
The dryer heater is not working properly. Call a repair technician.
Alternatively, create a custom wash cycle with no dry cycle and hang dry the laundry if you are past warranty and do not want to pay to repair it.
SOURCE: My 1988 washer/dryer combo Model
The "E9E" code means Low Voltage is seen at the Control Board. Make sure the RED wire on the Control Board that connects to the Heater Relay is not loose or burnt. This is the LINE ONE voltage supply to the Control Board and if it has a bad, loose or burnt connection it will cause E9E to display. If there are no loose of burnt wire connections then the control board will likely need to be removed and replaced.
