Carol - I'm having the same problem with 2 of my Candle Impressions timer candles. They don't turn off automatically & stay lit 24/7. Did you ever find a solution for yours?Carol - I'm having the same problem with 2 of my Candle Impressions timer candles. They don't turn off automatically & stay lit 24/7. Did you ever find a solution for yours?
You can't post conmments that contain an email address.
Re: Timer is noot working on luminary candle.how to fix....
I had an issue with these before, put a dime under the front middle of the base, it should fix it, if its the same problem i had. can you tilt it and will it work? sometimes when the base is not flush this tends to happen.
Luminarahttps://luminara.com
The realistic flicker technology behind every Luminara flameless candle has whimsical roots, having been inspired by the candles created by the imagineers ...
If your Luminara candles dont light try reseting the timer. To reset the timer, push the power button to "OFF" setting and then push button two times at the desired start time. Candle may be used with Luminara remote control. When the Luminara candle is switched to the ON position, you are able to turn the candle OFF/ON with the Remote.
To turn candle off, slide power switch on bottom of candle to "OFF" position. TIMERTo set timer, slide the power switch to the "TIMER" position. Candle will remain on for 5 hours from the time you place the candle in "TIMER" mode, and then automatically turn off for 19 hours. It will repeat the same cycle daily.
If you have those shown below, you may have the batteries in wrong.. both batteries must face the same way, most likely positive side up. There is no on/off switch.
It seems (without being able to see the item) that the bulb is not working. It's normally and LED type bulb and not normally replaceable. But, it does depend upon which type of candle it is.
Flameless
candles are made from beeswax like regular candles but instead of a wick they
use Led lighting to illuminate the candle. They look very realistic but are
much safer than regular candles.
