If it's a quill stem, you have to loosen the bolt at the top of the stem, and then tap it (the bolt) with a hammer to release it. There will be a line on the stem portion that goes into the head tube of the bike that tells you how high the stem can safely go. You will likely get to this maximum setting before the cables are stressed. Tightening the stem back in the head tube is just aligning it and then using the wrench again. There are Park Tools videos (and others) on Youtube that show this procedure, and cable replacement, if you need it.
SOURCE: Quinny Buzz Handlebar
I have the same problem too! To remove the handlebar set it to its longest position, then shorten it by 1-2cm. You will find that the plastic locking pin that you described is just a pair of lugs. With the handle bar in the above position you can then push both lugs in similtaneously while at the same time levering the plastic part out of the tube. when both sides are released the complete handlebar can be removed. From there it's fairly straightforward to strip down.
My problem now is that I can't find anywhere to get the parts from.
Any joy yet?
SOURCE: fixating mechanism in handle is broken
i can't figure out where your stroller handle broke! if there's a possibility that you could send me an image (close catch) on the broken part and rear view of the stroller, email it to me in jpeg or pdf type..... here's my email address... [email protected]
we'd like to help you much...
SOURCE: Riding position
i agree, higher handlebars will keep you relaxed on a long ride, depending on the terrain and the riding style.
but to have an idea on what handle bars risers to get, here are the OEMs
Click on this link
SOURCE: Extending subwoofer cable
The subwoofer signal is fairly hot, so you can go pretty far without significant signal degradation.
Use standard shieled audio cables and cable couplers to do this. I wold say you cold run it 50 feet without creating a problem.
SOURCE: max cable lenght for cat 6e cable
The cable standard provides performance of up to 250 MHz and is suitable for 10BASE-T / 100BASE-TX and 1000BASE-T / 1000BASE-TX (Gigabit Ethernet). It is expected to suit the 10GBASE-T
(10Gigabit Ethernet) standard, although with limitations on length if
unshielded Cat 6 cable is used. Category 6 cable can be identified by
the printing on the side of the cable sheath.
Cat5e is suitable for 10/100/1000baseT ethernet for 100 meters, when properly installed.
Cat 6 is also good for 10 gig ethernet for 37 meters, but that is pretty short, unless just in a server room.
There is no Cat 6e, but Cat 6A will be good for 10/100/1000/10GbaseT ethernet for 100 meters.
Unshielded
Twisted Pair has no ground shield around the wires. It is the standard
in the US, where most network standards were defined. There are
extensions to the standards to allow for the more common in Europe,
Shielded Twisted Pair.
Some Cat-6 cables are too large and may be difficult to attach to 8P8C
connectors without a special modular piece and are technically not
standard compliant. If components of the various cable standards are
intermixed, the performance of the signal path will be limited to that
of the lowest category. The maximum allowed length of a Cat-6 cable is
100 meters (330 ft) when used for 10/100/1000baseT and 37 meters
(120 ft) when used for 10GbaseT. This applies for UTP cables only.
Shielded Cat 6 and Cat 7 cables are capable of 100m.....sodeep
