Televison & Video Logo
Posted on Oct 26, 2018
Vizio tv 42 inch main board replace
I replaced the main board in my tv, Now the picture is upside down. Is there a setting on the board to turn it over?
Greg Salzmann
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Oct 26, 2018
Greg Salzmann
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1996
Points
13
Compare the two side by side, double check your connections,check the pins,are they in the same line up +/-, did you ground yourself before doing the install
Testimonial: "yes I do."
  • Alian04 Oct 26, 2018
    all components are the same. only difference is on part number label. original board says v2.38.4
    replacement board says v2.38.3
    problem with the original board is the coax input plug broke off. I may just send it out to be repaired.
  • Greg Salzmann
    Greg Salzmann Oct 26, 2018
    take the part off the new one to fix the old one
5 Related Answers
Anonymous
  • 5 Answers
  • Posted on Sep 06, 2008
SOURCE: picture is upside down Samsung HLR 4667W 46 inch
Enter service.....go to engine and change engine type. This work
Anonymous
  • 56 Answers
  • Posted on Feb 17, 2009
SOURCE: Plasma Vizio 42 inch
The main board of your TV is bad. I have seen a lot of TVs have the same problem.
ginko
Ginko
  • 19396 Answers
  • Posted on May 04, 2009
SOURCE: 42" Vizio - no picture no sound
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Pay particular attention at inverter and power board, power board can be inspected looking for bulged or leaking capacitors, then tested with a multimeter. The inverter is more difficult to test , there is need to read voltages, should be done by a tech. Also the LCD controller board can cause same problem
nicknovikov
Nick Novikov
  • 101 Answers
  • Posted on Oct 05, 2009
SOURCE: how much do amain board cost on a 42 inch vizio tv
shopjimmy.com.check this site.
toddthetvmd
Todd Thornton
  • 101 Answers
  • Posted on Oct 26, 2009
SOURCE: i have picture but no sound on my 42 inch vizio
If you received a remanufactured board it might be defective,Or did you forget to hook back up the speakers? Sounds dumb but happens alot. Speaker wires get in the way,we disconnect them to look at a board or replace one.Often gets over looked.But I have received several defective boards.Hope this helps. Toddthetvmd
I have fussion led 32 inch tv i pressed reset it turned picture upside down how can i fix it
Go to service mode and there should be an option to flip the picture, not sure why this should happen when selecting reset as its more common when replacing the main board
Vizeo tv no picture
If audio is OK, the fault would be with its back-light inverter. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
LVDS issue with RCA 46 inch LCD TV
If you wish to get some details; check the site linked here. Pull up older posts.
Reasons for upside down picture are given.
Vizio 42 inch powers on but there's no picture no sound no I put a new capacitor in my vizio 42inch now it won't come on Vizio 42 inch won't turn on
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis.
1helpful
I have picture but no sound on my 42 inch vizio p42hdtv10a got any ideas? I just replaced the main board and got the picture back but no sound.Sound worked before replacing main board.Any ideas would be...
I have a 42 inch vizio VW42L and a few months after I bought it sometimes when I go to turn the set on I get sound but no picture. To the point where the backlight of the tv doesnt even turn on. I usually...
Tell Vizio send out the tech.to replace ur Backlight video inverter board,it dying go to be dead sooner or later.Or take the refurbished tv ur tv will have dead video soon.
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
