Aftertheprogrammehasstartedthedoorislocked.If,for any reason, you need to open the door, set firstly the appli- ance to PAUSE by pressing the button 9. After a few mi- nutes it will be possible to open the door.
If the door remains locked, this means that the appliance is already heating or that the water level is too high. In any case, do not try to force the door!
If you cannot open the door but you need to open it you have to switch the appliance off by turning the selector dial to . After a few minutes the door can be opened (pay attention to the water level and temperature!). After closing the door, it is necessary to select the programme and options again and to press the button 9.
https://www.electrolux-ui.com/DocumentDownLoad.aspx?DocURL=2013%5C192%5C978810EN.pdf
This error means the washing machine door will not open promptly or might not open at all. It could be caused by a number of potential issues from wiring faults to damage to the door lock..
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
SOURCE: Washing Machine Door won't open
I had the same problem. I went through all the steps on this thread to no avail. Finaly I just pryed the thing open - with no damage, thank goodness.
Once open I saw that the latch in the door didn't move when I pulled the handle. The problem it seems was in the latch on the door itself. If you end up this problem and want to get wet clothes out, just stick a flat-head screwdriver, behind the door latch into the horseshoe-shaped metal bit and lever it open - no prying necessary.
Not sure how I'm going to fix this permantely but at least I got my wet clothes out and can do laundry as long as I keep the screwdriver near by.
To fix - I'll either need to figure out how to disassemble the door and replace the latch mechanism, or just buy a whole new door.
SOURCE: Washing Machine starts, squirts water, then stops.
E5E IS FOR Communication problem. THERE IS 100 %WIRE SHORTING SOMEWHERE.PLEASE CHECK OUT.
ALSO OTHER ERRORS
Error code - Fault condition
E11 Fill time too long.
E13 Water leak in tub or air leak in air bell.
E14 Reed switch.
E21 Water not pumping out fast enough.
E23 Drain pump relay on control board failed.
E24 Drain pump relay on control board failed.
E31 Better models. Pressure sensor not communicating with control board.
E35 Better models. Pressure sensor indicates water overfill.
E41 Control board thinks the door switch is open.
E42 Door remains locked after cycle is completed.
E43 Control board problem.
E44 Control board problem.
E45 Control board problem.
E46 Control board problem.
E47 Board thinks the door PTC circuit is open in spin.
E48 Board thinks the door PTC circuit is closed.
E52 Bad signal from tacho generator.
E55 Motor overheating.
E56 High motor current.
E57 High current on inverter.
E58 High current on motor phase.
E59 No tacho signal for 3 seconds.
E5A High temperature on heat sink.
E5B High temperature on heat sink.
E5C High temperature on heat sink.
E5D Communication problem.
E5E Communication problem.
E5F Communication problem.
E67 Input voltage on microprocessor incorrect.
E75 Better models only. Water temperature sensor circuit.
E76 Better model only. NTC temperature for the cold water valve over the limits.
E95 Communication error.
EB1 Incoming power frequency out of limits.
EB2 Incoming line voltage above 130 VAC.
EB3 Incoming line voltage below 90 VAC.
EF1 Clogged drain pump.
EF2 To much soap.
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
SOURCE: Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Testimonial: "Thank you so much - exactly right"
