I've tried resetting the camera, re-formatting the SD card, bought a new SD card and then formatted it, took out the battery, took out the card... So far, nothing is working. Any help you might provide is very much appreciated.
SOURCE: how do i format the memory card in a fz 38camera
Go into the menu and scroll to "format" and follow the on-screen instructions.
SOURCE: Panasonic lumix DMC-ZS1 - won't record video
It might be telling you that the card you have in the camera isn't fast enough to keep up with the demands of a video recording. You need to buy a more expensive card with a faster speed rating.
SOURCE: HOW DO I FORMAT AN SD CARD FOR MY PANASONIC LUMIX
be sure it is not blocked. (it has a locking button on the side) and after that into the menu of the camera look for format reset card ...this is the best way to do it cause it will format it on the way camera will support it ...Beware cause this will delete all your pictures..
usually the format feature will be on the view picture mode...around the option for delete single or multiple picks..
but if this is too hard ..just nsert the card into a card reader in a laptop or computer ...go to my computer folder...it will be seen as a removable storage device ..click right on it ..and than format ...choose to format in fat 32 not in ntfs cause the camera may not read it after that ..
so ...fat or fat 32 will be the mode...and if you have patience do not do it in the quick mode..cause it may cause damages in the long term ..(after a few times)
SOURCE: When I turn on my
Go to camera Menu and look for memory card settings/ format option, select format and press OK to format memory card.
SOURCE: m having Panasonic Lumix DMC-FH3
Sounds like the card is from another camera or was formatted on a computer. If there are pics on it you want to save, download them using a card reader if necessary. Then, format the card in your camera.
Can you format the SD card using the camera itself instead of a computer to do so, if that is what happened?
What capacity SD card is it, e.g. 64 GB? 128GB?
Other possibilities to look at are the type of SD card. SDXC cards said to cause problems with some cameras.
