I have followed the diagnostic procedure, but does not give a F or E code. I have replaced the water inlet valve, and pressure sensor. The lid lock is good, and have all the proper values for the switches and controls. What could be the problem?
First thing is check the clear fill sensor hose and make sure it has no pin hole in it. U can put finger over 1 side and blow thru other while submerging it under water and look for bubbles. If u see bubbles just wrap it in black tape. It just needs to hold air. If u dont see bubbles then replace fill sensor
SOURCE: Filling With Water
This is probably a control board failure, which should be replaced by someone familiar with them.
If you are handy, you can do it yourself.
If you need assistance, let me know.
Set the water level selector to a lower level. The sensor will always work if the water level is much higher than the trigger level. However, the "much higher" condition is never reached if the water is about to overflow.
SOURCE: Whirlpool washer overflow during wash cycle
What you can try is to get the machine empty and remove the hose that connects the pressure hose to the switch and blow air through it to make sure it is clear, then tap on the nozzle where the hose connects on the switch to make sure it is also clear.
SOURCE: kenmore elite h4 washer fh code
F/H is a no water fault code, so i would recheck your incoming water supply, or look to a problem with the inlet water valve.. if your using stainless steel hoses, form the manufacture lableld FLOOD SAFE, these maybe your issue as well they have a buitl in water shut off, htat may be failing preventing water from entering
SOURCE: troubleshooting kenmore washer 800 series
You will need to replace the lid switch. If you could post the model number under the lid, I will be able to direct you to the part you need.Here is a video to show you how to make the repair.
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
