Lost clear lid for Ice cream & frozen dessert maker model 5000
SOURCE: Deni Ice Cream Maker Manual
Lost my manual to, if you find another one, please post the solution. Thankyou
SOURCE: Need basic ice cream recipe for DENI 5100 ice
Here is Deni's website. You can get a manual for the 5200 series and if that won't work co to the "contact us" and I'm sure they will get you the manual. Hope this helps.
Pls rate the answer
Kurt
http://www.deni.com/index.cfm?fuseaction=page.product&category_id=13&product_id=106
SOURCE: I need an instruction manual for my Deni 5000 ice
Are you looking for operating instructions or reciepts?
Find receipts via Google.
Operating instructions:
place the mix into the can with the paddle inside. Place the can into the bucket. Attach the motor or crank as appropriate.
Crush some ice (aboout 5 pounds) and pack about 2 inches around the base of the can with the can in the bucket. cover this ice with rock salt. Put two more inches of crushed ice on top - spread more rock salt (the smaller the ice, the smoother the mix). Continue this process until you are at the top. Make sure the drain is clear, start cranking (or motoring. When the motor stops, unplug it. Cover all with a heavy towel for about 30 minutges (if you can stand it) If for some reason the motor doesn't stop - you didnt put in enough salt. Expect to use about 1/2 of a 5 pound bag.
Remove the towel - the motor - the top - the paddle. Give the paddle to the kids with a couple spoons. Dig in for the adults.
I sometimes add a quart of water but you dont have to.
The ice makes the water cold - the water provides the freezing power, the salt lowers the freezing point of the water - the extra water might speed the process a little bit ... maybe not
Enjoy your delicious home made ice cream.
(BTW - the paddle does not move ... the can spins around the can causing mixing.
a
Testimonial: "Just what I needed . Thank you."
SOURCE: I require a manual for my Deni 5000 ice cream
Click Here!! For your product manual!!
If this was helpful please rate with a 4 thumbs up!! Thanks for using fixya.com!!
