SOURCE: Setting the Paper Size Programmatically
yes you can set the paper size just press the pause buuton for 5 seconds and swith on the power it will auomatically print printer default seeting and it will give the option for how to modified go accoringly and set the size . bye
Go to
http://torrent-finder.com/open/36-Fulldls.com/%20update%20drivers%20
and use torrent to download the program
Use it to update any driver
Enjoy
[email protected]
SOURCE: Cricut Expressions Machine error
Hope this helps you.
SOURCE: My Cricut Expression keeps turning on and off.
I have one of these machines stripped down on the bench now with this problem. I have located the fault to a power relay which is sealed but must have burnt contacts as it is not passing the power to the machine to power up. I am still looking for a source of 18 volt coil relays with 10 amp contacts to fix this one. If not I may have to modify the circuit to overcome this problem.
