SOURCE: Bosch Maxx - softener not dispensing into machine
It blocks very often , give it a good clean..remove soap dispenser to do so
SOURCE: washing machine i not draining out. bosch maxx
two possible reasons that you dont drain pump is blocked or to much soap,
SOURCE: My Bosch MAXX WFL2260 washing
If the belt is good and motor spins, then the drum bearings are bad. Try spinning the tub by hand. It should spin freely if the bearings are ok. If it does not spin freely, then the bearings are likely bad.
If you have removed the belt from the motor and tub and motor is not spinning, then the motor is likely bad. You can check the power to the motor with a voltmeter to see if it is getting power.
SOURCE: Bosch Maxx WLF 2000. No
Sorry but with such a fault it is extremely difficult for anybody on this forum to remotely guess what is wrong with your washer.
It could be internal wiring/plugs sockets, control panel switches, control PCB, water inlet control valves, door solenoid as primary suspects. Secondary suspects could be main motor, drain motor.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
Sorry again and good luck,
John C
SOURCE: Hi. I have a
The door lock has failed & needs to be replaced DON'T TRY TO GET IT OPEN it will cost you more money in parts that could need to come from overseas get a professional out who can pull it apart & open it from the inside.Most repair men carry these parts in there van best to ring a bosch agent.
Just to add... I have tried all settings and sometimes it works but other times cuts out as soon as I turn on power so it's not on a specific cycle that it cuts out it can be on any cycle
You may need an electrician
