SOURCE: Konical Minolta 2430 dl Streaking
Try cleaning the rollers. Directions can be found starting on page 83 "Maintaining the printer" here:
http://www.kn.nl/data/handleiding/174952/user%20guide_engels.pdf
SOURCE: when typing 192.168.1.99 in the address book of IE
Bizhub needs a frmware upgrade. There was a firmware issue which caused this when .NET Framework 3.0 was installed on the PC.
SOURCE: unable to print from after attching to dlink printer server
check the paper type in the driver, it might be setted to Letter and you are trying to print as A4 or A4 to letter.
SOURCE: The print margins on my Konica Minolta Bizhub c203...
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
SOURCE: FileName : Private.Practice.S04E11.HDTV.XviD-LOL(2).avi Header Data :
So what is the question as these are just machine codes from what?
