SOURCE: amana oven
Error
F-9 means:Door lock safety circuit on ERC sensed Replace the door latch assembly
To solve this...Just press and hold the door latch to unlock position and then press
cancel for a few seconds. The latch will return to its original position
This will probably fix it..but if doesnt work try this
Try unplugging the oven from the electrical power. May release the
lock, which is held in place by a tiny micro switch. If not and while
the electric is still off or the oven is unplugged, use a bright light
flashlight to look through the slot where the lock is in the oven, not
in the door.
You may be able to use a thin blade screwdriver to move the lock to the
release position. Check the angle of the lever. A slightly bent lever
handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to
access the locking device and release it. May have to disconnect the
wires to the lock which will allow door to function but not during any
self cleaning modes.
SOURCE: control lock light
someone has enable the child lock feature. One of the buttons should say hold 3 secs for control lock under its normal function description. Hope this helps
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
SOURCE: Maytag front loader washer--door won't open but lock light off
Open the soap dispenser. Look down in front of the fabric softener dish.
You should see a yellowy-green plastic cord (like weed-whacker line). Pull it.
The door should open.
If you don't see the cord, remove the four screws that hold the dispenser lid in place to find it. Just don't lose it when you put the cover back on.
