SOURCE: How do I change an electronic safe combination?
hi, on mine if you open the door their is a red button press and hold for five seconds, then release put new code in then press again for 5 secs turn thelock to lock position do not close the door, put in the new code and see if it ulocks, if so, bingo, DO NOT CLOSE THE DOOR TILL YOU ARE CERTAIN THE CODE YOU PUT IN WORKS, hope this helps, mine only has a four digit code but i think its the same set up.
SOURCE: century safe lock , not able to open the combination lock oper b
just boughy it and instructions got thrown away by accident . I have keys but no combination please advise..... Numbers on door that are tagged on is: BJ-285913* an another sticker that says 50310 BJ285913 please advise...
SOURCE: How do I open the combination lock to my sentry home safe?
Locksmiths advise these Opening instructions for sentry fireproof electronic security safes. Insert the tubular sentry key into the lock to the left of the key pad. Turn the key all the way to the right until the plunger pops out. Press the five-digit factory code. The green Proceed light will come on. Pull the handle down; to crack the sentry door open.
sentry safes opening instructions for 4 # combo locks
Turn the dial to zero.
Turn the dial to the left (counterclockwise) four times to the first number of the combination (pass the first number of your combination three times, stopping on it the third time).
Turn the dial to the right (clockwise) three times to the second number of the combination (pass your second number twice, stopping on it the third time).
Turn the dial to the left (counterclockwise) two times to the third number of the combination (pass the third number of your combination one time, stopping on it the second time).
Turn the dial to the right to the last number (stop the first time on your last number).
Pull the handle down to crack the sentry safe open.
SOURCE: I have a Meilink safe
Hello.
Give this a try:
Opening a Typical Dial Combination
Safe
1. Turn the dial left past the first number 3 times and stop on the
forth time.
2. Turn the dial right past the second number twice and stop on
the third time.
3. Turn the dial left past the third number once and stop on
the seond time.
4. Turn the dial right until the dial stops at the last
number.
5. Turn the handle
Note: Be careful and make sure you follow it perfectly
Hope this helps.
