SOURCE: keyless entry remote
Check inside the remote case...there's instructions printed that tell you to hold the lock and unlock buttons for 7 seconds to reset the remote. I'm in the middle of replacing batteries myself. Let me know if it works.
SOURCE: keyless entry won't work
I have a 1999 BMW E46 I have had a problem with the keyless entry myself. I brought the car to BMW Dealer and they told me that my Lock had an issue and that they need to repair some wiring wich would cost me $1,023.98 to find out that it was a fuse that burned out. I have replaced the 5 amp fuse with another one but it burned the fuse again so I put a 10 amp fuse and i have not had a problems since. In my car is fuse # 54 if Im not mistaken. But waht you can do is open the fuse box which is located in your glove compartment look for a diagram that shows you which fuse is where it will give you a fuse name a number where the fuse is located and how many amps fuse it is.
SOURCE: set the keyless entry
TS06 DEC 05 Keyless Entry - Transmitter(s) Inoperative
There was a recall in DEC. 05 for this particular vehicles remote transmitter system....though im not sure if they would do service free of charge now...
Moving along...if you have no working transmitter, you have to do the following to get it working again:
* Ensure vehicle audio PIN number is known or audio PIN security system is deactivated prior to battery disconnection.
* Ensure a door is open
* Disconnect the negative battery cable, wait minimum 5 seconds then reconnect
* Within 20 seconds of reconnecting the battery cable, insert the keyin ignition then cycle the ignition key from the "ACC" position to the"ON" position 20 times, leaving the key in the "OFF" position after thetwentieth turn.
* the vehicle's indicators will flash 20 times to indicate successfulentry. NOTE: Should the indicators fail to flash, wait 5 seconds thenquickly turn the ignition switch from the "ACC" to "ON" position 10times, leave the ignition "OFF" after the 10th turn and wait 15 secondsthen recycle the ignition switch 20 times.
* the vehicle's indicators will flash 20 times to indicate successful entry.
* within 10 seconds of the indicators having ceased flashing, press the button once on each transmitter.
* turn the ignition key to the "ON" position to lock in and exit from the programming mode.
And if you have even 1 transmitter that does work, its not nearly as difficult:
* ensure a door is open
* remove key from ignition
* lock the doors using the transmitter
* unlock the doors using the transmitter
Within 20 seconds of unlocking, insert key in ignition, turn theignition key from the "ACC" position to the "ON" position 20 times,leaving the key in the "OFF" position after the twentieth turn.
The vehicle's indicators will flash 20 times to indicate successful entry.
Within 10 seconds of the indicators having ceased flashing, press thebutton once on each transmitter. Once finished, turn the ignition keyto the "ON" position to lock in and exit from the programming mode.
Hope this helped,
Jem
SOURCE: keyless entry for 05 Kia Sportage
i have a kia optima my keyless quit working to.I took it back to the dealer and the said it was common on a lot of kia models.They replaced the module for the keyless remote,that seams to have fixed it.
SOURCE: How do i program remote keyless entry?
You don't normally program a keyless entry, that's done for you by the technicians that install that. If the replaced battery doesn't solve the problem, take the battery and the remote to the techies that installed it.
