SOURCE: Westinghouse 32in HDTV-Ready
I called westinghouse with a similar problem(my picture shows up but all the white turns blue or somtimes pink).
they say the problem is similar to that of the xbox 360's red ring of death problem. Now what needs to be done is the unit needs to be unplugged completely for about 30 minutes. this allows the unit to completely cool down. and when the unit restarts and heats up the troubled connections will reflow and all will be fixed.
I tried this and it worked well for my TV. but it is only a temp fix and will need to be done again if the problem occurs.
SOURCE: White lines across the top of the screen
It sounds as though you can see Transmission lines which are sent out with any broadcast at the top of an image, The TV should normally blank these out, i suggest checking your horizontal and vertical settings
SOURCE: Wiring instructions are terrible. Ceiling wires =
That is dificult to follow .. here is the usual wiring plan for ceiling fans .. green to green or bare and mounting bracket ... ceiling black and red are live from the switches, fan and light.with a remote you really only need one of these , so cap off the red and use the black as your input to the remote .. the neutral to the remote should be the white .. there are only 3 wires from the fan so I am assuming that there is no light , or the light will be activated from the remote .. the black for the fan and the black for the lights connect to marked wires on the remote. .. lights out, fan out
or looking at your description .. ((Remote wires = Neutral in(Black) white ceiling wire, Live In(Black) blaxck ceiling wire, Light out(White) blue Fan/Light wire, Fan out(White) black fan/light wire, Common(White) white ceiling and white fan/light wires.
SOURCE: The instructions ( Hampton Bay
this is wired correctly.
Testimonial: "That would have been a good suggestion while I still had some daylight ! I can try that tomorrow."
SOURCE: white flickering line across top of screen
Set the screen format using your TV's menu. Do not set the format of the screen using your provider's receiver. I had this prob with a few channels with a dish provider when I set the format with the remote from the dish provider. I picked up the TV's remote, went into the menu, set the format, problem fixed.
