Requires removal of the drum and developer unit 2 small screws and the large one in the middle. which holds a locking device. Then remove the charge corona assy. developer unit. Replace the drum with a new cleaning blade. Ensure the Drum Density sensor is cleaned. And Paper Jam senor. As you can see its not easy. recommended a tech. or purchase download service manual.
SOURCE: I want cd for instale KONCA MINOLTA PAGEPRO 1300W (driver)
Try this driver (choose the operation system)
http://crm01.konicaminolta.eu/openmind/technic/kmpsdwl.nsf/psearch?OpenForm&ch=PRI&dist=BPE&ui=en&dg=sw&prod=PagePro%201300W&dsg=&os=&lang=&ml=0&rid=41256849005CE173&sub=Printer%20Driver&pcat=B%2FW%20Printer&pcc=1
don't forget to vote!!!
SOURCE: konika minolta
CDC## Appears to be trouble related to security.
The only solution is to contact Konica Minolta to find out what needs to be done to resolve the problem.
That is only solution the service manual has provided.
SOURCE: Konica Minolta Magicolor 2400W drum cartrige-how to replace?
Did you buy a whole new drum unit, or just change the cartridge? If so, the fuse may still be blown. Also, you may need to empty the spent toner out of the old cartridge.
SOURCE: service call 05H
Flash ROM upgrade failure. Engine firmware upgrade failure. Attemp to re-upgrade. Check for proper firmware,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
