SOURCE: Meiko FV40.2 Error codes
212
Boiler temperature too high
Contactor faulty, probe faulty, check connection on XA5
The code 312 is the same as a code 212 as stated above.
There are dozens of error codes and you should be able to get them from your local meiko dealer, hope this helps, colin
SOURCE: dishwasher fix
111
Floor pan Leakage
Leak inside machine activating ground float switch
302
At pumping out during rinse cycle level does not fall below level 1
Drain pump faulty, blocked, aqua stop not closing completely, no signal from circuit board (connection number 6 on XA1 connection plug)
SOURCE: i need an instruction manual for meiko ecostar 530f dishwasher
Go here and see if your manual is there...I hope this helps...thanks for rating my effort.....The Fang
http://www.meiko.us/downloads.htm
SOURCE: Meiko dv80.2 error 201
Error code 201 Indicates the incorrect water level...in that the level was not achieved during filling...check the following.
Correct water level was not reached during initial filling.
Check that the water hose is correctly attached and is free of “kinks” or pinching. Also check that the water supply is turned on.
I hope this helps...thanks for rating my effort....the Fang
SOURCE: ERROR 203 on MEIKO MODEL D 120.2
error 203 means , no change detected by the level switch when draining . possible cause
1, booster pump faulty
2, booster pump plug connector loose
3, start capacitor faulty
4, plug connector loose
5, boiler level switch faulty
6, no boost pump signal to- i/o pcb
7, no "boiler full" signal from i/o pcb check booster pump/ s2with manuel control
the most lightly or most common is the level switch in boiler tank will need changing
