SOURCE: replace drum bearing
To complete this repair correctly and to prevent problem re occuring within months you must change the inner drum spider at the same time as the bearing kit, otherwise you are wasting your time, to complete the repair if you have not done one before will take you aprox 1 to 3 hours depending on space available and practicle ability, here goes, remove lid and outer case from machine to do this remove bolts on lower back and two side bolts (under small white covers) remove bolts along top edges both sides on top of macnine, remove cabinet, remove motor, remove hoses, remove heater and thermostat wires, noting location for refitting, remove suspension leg pins and lift outer drum assembly complete fron lower frame, split two halves of outer drum by removing bolts around centre seem, split drum in two, remove drum pully, refit pully bolt and drift inner drum out having put nut back on drum spider thread to avoid flaring shaft, using hammer knock shaft through bearings, then using a chisel or similer object knock out bearings and seal, reverse process refitting new bearins and spider, make sure to replace centre outer drum seal, as these are prone tro leaking I suggest you also seal with a layer of clear silicon, and problems contact me again, not really a job for a novice. Good Luck you will need it. Regards Advisor
SOURCE: Samsung washing machine filter
it has a self cleaning filter. if you want to clean out the tub and filter thoroughly then:
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
SOURCE: really bad smell from drum?
Power off the mains. The filter is located behind
the silver plate at the back of the machine at the bottom. Four
screws hold it on. Drain out all the water. The filter is
inside the big black rubber hose attached between the pump and the main
drum. Remove the plastic clip holding it to the pump unit and then the
metal cir clip holding it to the main drum. Inside is a white molded
cone and a big white ball which floats. You will find a lot of junk
here, clean out thoroughly. To refit put white cone back inside just as
you found it, at the bottom, fit ball back into the cone. Attach to the
bottom to the drum and re-fasten the cir clip. Finally reconnect the hose to the pump unit and tighten the plastic clip. Check out the pump
too before reconnecting. Being the first time you shd note what you doing, what goes where. You certainly don't need techs for this; and techs who come are useless anyway.
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Pl give me a ‘very helpful’ rating for the free help,
thanks!
SOURCE: drum smells
Open the door and run your hand deep inside the door seal. It probally has a slime around it. You can clean this with a bleach water mix. You might need to pull the seal somewhat inside out to get it real clean. Then run an empty load to flush it all out. Here is a link for replacing the seal or spring clips if you pull one off. http://appliancehelponline.com/washerdoorseal.html
Testimonial: "had already run a boil was to no avail. however after washing the inside with bleach solution and leaving overnight it seems ok again."
