Crafts & Hobbies Logo
H
Hannah Wiley Posted on Sep 30, 2018
I'm trying to hook up Lionel's Western & Atlantic Horse Car and Corral. How do you hook it up with the Fast Track Operating Section? We have all the pieces.
Moz Empire
Level 1:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Contributor 47 Answers
  • Posted on Jan 14, 2019
Moz Empire
Contributor
Level 1:
New Friend:
Cheetah:
Answers
47
Questions
0
Helped
31081
Points
79
Check the Lionel website.
5 Related Answers
Anonymous
  • 825 Answers
  • Posted on Aug 04, 2010
SOURCE: while instaaling fast track pro
it requires a higher standard operating systems to install this software... if you are running in windows Xp try upgrading to vista and install the software... if you are already running in vista or win7 then it says that it requires a 64 bit operating system.....
Anonymous
  • 6 Answers
  • Posted on Jan 11, 2011
SOURCE: i have a lionel legacy cab-2 remote i hooked up
just unplug the transformer from the grey box (the one with the green light and red light) and check the voltage. if it doesn't read anything, try unplugging the transformer from the outlet and plugging it back in again. if you get a reading, replug the transformer to the grey box and check the voltage of the silver screws (where you put the + and - wires from the track to) and try using the train again
Gerald Lewis
  • 34 Answers
  • Posted on Sep 05, 2011
SOURCE: CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK
Track power is not recommended for this uncoupler. Use an aux fixed supply of at least 10 to 13VAC for the supply. You have to move a jumper on the bottom of the track to do this. Then there will be four wires needed. Two for the aux power (hot and common) and the other two which go to the pushbutton switch.
Note: Same goes for Lionel FasTrack Remote switches. Run the switches from a 10 to 12 VAC aux supply. There is a jumper you remove on the bottom of the switch to connect an aux supply.
Gerald Lewis
  • 34 Answers
SOURCE: Purchased a Lionel New York
The magnet may not have enough punch using track power. Recommend you use an aux power source fixed 10 to 13VAC supply and not track power. There may also be a slight + difference between the track magnet head and the plate on the coal car so that there is insufficient force to release the dump mechanism.
Anonymous
  • 747 Answers
  • Posted on Sep 04, 2012
SOURCE: I just bought a new lionel o guage remote control track section. My train can run around the oval 3 or 4 times and the uncouple button will cause a coupler to uncouple properly. Then the magnet in t
sounds like a contact issue clean all connections make sure they fit tightly when a bad connection occures it will cause metal to heat up check both sides of the circuit with an ohm meter
1helpful
2answers
I am having problems with Lionel Fastrack layout. When I put electrics to the layout the green light comes on and I think all is ok. However as and when I start to increase the power the red light A.
remove all the cars and engine from tracks and try it, if green stays on add one car back to track at a time and try it , when light turns red , the last car added is the problem
The Lionel lines train is going too slow and it
time to clean & lube your train & track.
here's a couple link's that should help :
Maintaining Your Lionel Trains
Cleaning Track
Lionel toys
see attached pdf.
Looking for instructions for lionel fast track automatic switch
Try contacting the Lionel Service Department on
586 949 4100 or use their website contact service. Contact Lionel Trains
CANNOT GET THE UNCOUPLING TRACK SECTION TO WORK THRU TRACK POWER - WHAT IS PROPER WAY TO HOOK UP RED AND BLACK WIRES? LIONEL FASTRACK
Purchased a Lionel New York Central Flyer Operating Freight Expansion Pack with a coal dumper. My set runs on O-gauge track, not fas track, but the magnet operation appears to be the same. The coal...
1helpful
Ι've just joined 2 ovals 40x60 lionel fastrack, used some other items 2 Lionel 6-12018 FasTrack O-36 MANUAL SWITCH RH, 2 Lionel 6-12017 FasTrack O-36 Manual Switch LH, A few 6-12014...
It sounds as though you may have two defective transformers. Lionel has reported problems with some of their smaller transformers. I would have the transformers and the engines checked by a Lionel service station or contact their customer service department for help.
Top Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
